Old 10-16-2005, 03:46 PM   #1
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Default I NEED SERIOUS HELP WITH MY EVO3
ok the thing is when ever i set my evo3 on the ground and pull the throttle it makes a sound similar to striping gears. As i asked people at the trank each person told my to check my diffs. I already did, i actually took my one way out and put two new diff in the front, i checked the gears and they should not be at that they will make the sound. I rebuilt my rear diff and no problems, and I already have space between my pinion and spur gear. I NEED HELP, i spent many many hours and still could not find out why!!!
Sushi Man is offline   Reply With Quote
Old 10-16-2005, 03:47 PM   #2
drew85's Avatar
Tear the car down to the nothing and check everything, theres no reson not to so stop be lazy
drew85 is offline   Reply With Quote
Old 10-16-2005, 03:50 PM   #3
BritRacer's Avatar
sounds like incorrect shimming on between the diff gear and the rear prop gear.
Take it all apart, and look again, something is stripping. Look for small peices of palstis in the diff cases.
I assume your diff is tightened correctly?
BritRacer is offline   Reply With Quote
Old 10-16-2005, 03:59 PM   #4
Sushi Man's Avatar
no the weird thing is that as long as i dont set the car on the ground and let the tire spin in jthe air as i hold the car there is no weird noise.
Old 10-16-2005, 03:59 PM   #5
Sushi Man's Avatar
yes my diffs are tightend
Old 10-16-2005, 04:00 PM   #6
BritRacer's Avatar
thats becasue when its in the air!!
There is no resistance, when its on the ground, a lot of torwue is applied to the gears.
Old 10-16-2005, 04:07 PM   #7
Sushi Man's Avatar
so ur saying that the connection with my propellar shaft and bevel gears on my diff is loose and stripps?
Old 10-16-2005, 04:20 PM   #8
Diagnosing problems like this over the interent is pointless. It could be anything. If you can't figure it out yourself, have someone more experienced at the track screw around with it.
Goonish is offline   Reply With Quote
Old 10-16-2005, 04:21 PM   #9
ChadCapece's Avatar
Your spur might be stripped.
ChadCapece is offline   Reply With Quote
Old 10-16-2005, 04:24 PM   #10
Sushi Man's Avatar
my spur is not stripped, i already did, i asked the fasted guys tehre, they either didnt know anything about the car or they were to busy, afew people helped my but they were busy.
Old 10-16-2005, 04:25 PM   #11
kartermdb's Avatar
Trader Rating: 15 (100%+)
does ur diff move around in ur diff case, if you didnt put any shims in it will seem fine but as soon as u put it on the ground and apply power the diff will move over and the teeth will skip
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 10-16-2005, 04:28 PM   #12
Sushi Man's Avatar
have u had experience with this car?
Old 10-16-2005, 04:55 PM   #13
bigtez's Avatar
if your talking about the tamiya evo3 i have the surikarn version. I also had a problem with noises. ik have noticedthe tamiya 0.4module pinion gears are too soft and get damaged easilyand that can cause a bit of noise.
the other thing i found to make noise is bent drive shafts. mine bent after a run in with the boards due to some clown turning his radio on in the pits. check them cause they will make a racket even if only slightly bent but it will be less noticeable off the ground.
Terry Langham
www.qrccra.org.au
bigtez is offline   Reply With Quote
Old 10-16-2005, 05:50 PM   #14
Suspended
your difff cases could also be stripped out check them too
THE_REAL_FROBOY is offline   Reply With Quote
Old 10-16-2005, 07:45 PM   #15
Sushi Man's Avatar
no the noise that vomes out is insane, its cvery loud, it not the pinion or spur, i checked the driveshaft, its fine.
Sirro .12 Evo3 5p and Evo3 3p(in pieces) Mugenville Australia For Sale/Trade 0 12-12-2007 07:58 PM
Need HPI EVO3 fix tip falconcg Nitro On-Road 8 05-12-2007 02:08 PM
G4 with evo3 Sirio goose Australia For Sale/Trade 6 05-17-2006 04:29 AM
EVO3 NEW!! Never run BigDogRacing R/C Items: For Sale/Trade 12 09-13-2003 12:39 PM
EVO3 like new BigDogRacing R/C Items: For Sale/Trade 2 09-12-2003 12:00 AM
