Old 10-15-2005, 01:44 AM   #1
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Default charging problems with novak ionic
hi, i have a novak ionic and it wont charge at 4amps, but it wil charge at 0.5 and 1 amp. can somone please help me.
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 10-15-2005, 03:48 AM   #2
Jack2's Avatar
2 things come to mind.
1. Your charger will not charge at 4 amps because the cells are ruined and need to be retired.
2. The charger has a fault and needs to be repaired or replaced. Check out www.teamnovak.com , the Novak customer support is very good and they should be able to fix it for you if thats what the problem is.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 10-15-2005, 04:50 AM   #3
A Ilievski's Avatar
its not the batteries, and one problem i live in australia. i cant really send it back to novak
Alex Ilievski
Old 10-15-2005, 06:40 AM   #4
beer_drinker's Avatar
If the batteries are fine you probably have to send it to novak. Just check them on someone else's charger to be sure
beer_drinker is offline   Reply With Quote
Old 10-15-2005, 06:51 AM   #5
which ionic do you have. one came with a power supply built in and the other was dc only. if you are using a battery as a power source then it must be the charger. if you are using a 12 volt power supply, then try a car battery to charge with. i had a power supply go bad on me a few years ago and it would only charge at 3 amps.
baih is offline   Reply With Quote
Old 10-15-2005, 07:05 AM   #6
A Ilievski's Avatar
its the acdc one. andc ive been using it off the wall, and i have tried a psu aswell.
Alex Ilievski
Please Help. Charging problems. J_ROD48 Electric On-Road 3 05-22-2006 06:19 PM
novak ionic A Ilievski Australia For Sale/Trade 1 01-13-2006 04:11 AM
Ice Charging w/ novak bars. Novak equilizer problems Khan48 Electric Off-Road 4 12-24-2005 11:50 PM
AA charging problems pullstarter Australian Racing 4 11-11-2005 12:23 AM
Novak Ionic rc10gt82 Rookie Zone 2 09-20-2004 08:14 PM
