Transmitter range issues >
Old 04-15-2015, 12:17 AM
Default Transmitter range issues
Hi guys, I have a basic 2 channel AM 27 MHZ transmitter from Tamiya (Adspec) and I feel that the range is exceptionally poor. Like the car would be about 3 meters away from me and the throttle input would be intermittent.
I have a few questions about this then:
1) When controlling the car, do I need to point the antenna toward the car? Or is there any other direction for such purpose.
2) Would upgrading to a 2.4 gHz provide greater range?
3) For the loose antenna from the receiver, I am currently just stuffing it where I could find space. Is the location of the antenna critical?
Thanks!
Corse
Corsa88 is offline
Old 04-15-2015, 12:45 AM
TB03Racer09's Avatar
1) Doesn't matter where you point it
2) Yes, more range as well an no more interference from other radios
3) The antenna should be in a plastic tube that sits vertically on the chassis, preferably away from other wires
Has the antenna ever been shortened on the radio or receiver?
TB03Racer09 is offline
Old 04-15-2015, 01:22 AM
Oh, the antenna has to be risen out of the car vertically? it currently sits in the body itself coiled up in a mess. Would that be a factor for poor reception? No the antenna was never shortened.
Corsa88 is offline
Old 04-15-2015, 01:24 AM
Yeah, definitely a factor. Also make sure you transmitter batteries are not flat and that you open the telescoping transmitter antenna all the way.
Old 04-15-2015, 01:30 AM
Thanks!
Corse
1) No
2) If your receiver and antenna are positioned correctly then technically speaking no...lower frequencies technically travel farther than higher frequencies. However your car is likely not set up properly for optimum reception so switching to a 2.4Ghz radio/receiver would give you better reception as antenna position is not nearly as sensitive as 27Mhz radio/receivers are.
3) For the 27Mhz system you need the antenna to extend up as high as possible. Best if it is extended through the body and is as far away from power wires as possible.
InspGadgt is offline
Old 04-15-2015, 06:58 AM
Roelof's Avatar
Check the antenna cable for a breakpoint. Also check if the transmitter antanna is screwed tight.
And a simple 2.4GHz GT2 transmitter can be found for just 30 dollar....
Roelof is offline
Old 04-15-2015, 07:42 AM
Geezatec's Avatar
AM27mhz & 75mhz radios require a 14" antenna tube raised out of body. Antenna wire or cable may have a break. You can attempt to replace if or purchase a 2.4 setup, and have the 5" antenna and long telescopic antenna to a short TX antenna, and be with the Jones.
Geezatec is offline
Old 04-15-2015, 09:56 AM
sakadachi's Avatar
Also check that your motor has capacitors soldered.
I run 75MHz FM on my older chassis still, for the old school fun of it , and the antenna is wound inside the body, no antenna pole. I have no issue driving it down the street. If I was going to race with it, I would definitely use my 2.4GHz.
sakadachi is offline
Old 04-15-2015, 10:12 AM
eR1c's Avatar
I hate AM transmitters ...they are always trouble sooner or later. The last one I used was in about 2007, -what a PITA.
Get a 2.4 ghz, -All your troubles will be gone!
eR1c is offline
Old 04-15-2015, 10:59 AM
Roelof's Avatar
It is very wrong to say there are no problems with 2.4ghz. With 2.4ghz you still have a wireless communication which can and will be disturbed..
Roelof is offline
Racermac73's Avatar
Been so long since I ran that stuff I forgot how annoying radio problems are. I would upgrade to 2.4 and be done with radio issues for good
Racermac73 is offline
Old 04-15-2015, 11:50 AM
(0000000000)'s Avatar
"Who has channel 72?!? I need the clip for channel 72!!!"
LoL
(0000000000) is offline
Old 04-15-2015, 11:57 AM
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
RED !
RedBullFiXX is offline
Old 04-15-2015, 12:23 PM
Racermac73's Avatar
Lol
Old 04-15-2015, 12:45 PM
howardcano's Avatar
Trader Rating: 37 (100%+)
I still have the clip from Las Vegas for 53.6.
howardcano is offline
