ball diff help
Old 04-14-2015, 12:34 PM
Default ball diff help
I have a mr4tc with ball diffs. My front diff just started slipping.
How do i tell if its just loose or if the balls are worn out?
What can i do to extend the life of a ball diff?
Im not racing just parkinglot fun with my kids.
turbo scorpion is offline
Old 04-14-2015, 12:54 PM
dan_vector's Avatar
Trader Rating: 27 (100%+)
The best way to do it is remove it from the car and strip it down carefully as per the manual. One stripped you can inspect the parts for wear and replace as required. You might need new rings and balls but you wouldn't know for sure until you take it apart.
dan_vector is offline
Old 04-15-2015, 04:50 PM
snuvet75's Avatar
Trader Rating: 16 (94%+)
You might have to sand the disks. Use 600 followed by 800 or higher sandpapers. Make sure to put a drop of silicon grease on each 4 corners of disks when you install it back. And when you clean the balls and disks before the service, get a small bowl, put some bearing cleaner or denatured alcohol, dip them, gentle agitation, let them sit for a few minutes, take'em out on clean paper towel, another shot of spray and then service and re installation.
snuvet75 is offline
Old 04-15-2015, 04:54 PM
Thanks!
Old 04-15-2015, 07:19 PM
Geezatec's Avatar
Never seen diff balls wear out, maybe the steel ring that ride agents them, just do maintenance often. if ringsge a groove flip them over.
Geezatec is offline
