Old 10-14-2005, 03:46 PM   #1
Default Integy Zero 030 Discharger Help
Hi I have question about this discharger. I was wondering the aligator clip come with the discharger what power should I connect to it said 12VDC where can I get that? Cause I have Novak N Power supply is that enough power?
I hope I made a good decision on buying this discharger.
Richard
Clangeddin is offline   Reply With Quote
Old 10-14-2005, 03:57 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I can't imagine you made a mistake buying it unless you payed more than 65$ US or it doesn't work. I have a cheapy computer ps (13 amp at best) and I run my ICE charger at 6 amps along with my ZERO30 and have no problems. You should be just fine. Plug the alie's on the corresponding pos and neg terminal of your ps.
Andrew
Old 10-14-2005, 03:58 PM   #3
So my Novak -N-Powersupply is more than enough?
Richard
Old 10-14-2005, 04:04 PM   #4
koabich's Avatar
Send a message via Yahoo to koabich
Richard
GOD yes, way more than enough. The cooling fans are the only thing that runs off of the power supply. If you do not hook it up to a powersupply, the fans shut off when the power of the battery is drained to the point where the bulbs on the tray go out.
koabich is offline   Reply With Quote
Old 10-14-2005, 08:22 PM   #5
geeunit1014's Avatar
at 7.2 volts, on my pulsar 2, the fans barley draw .3 amps, so you're more than covered
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-14-2005, 09:28 PM   #6
rc-zombies's Avatar
the cells get drained anyways... the discharger brings the cells to "0" volts.
the fan is only there to cool the resisters and cells.
Old 10-30-2005, 11:00 PM   #7
29TC's Avatar
Send a message via ICQ to 29TC
Hey guys, I just got this discharger. I hook up the fan and noticed that its blowing air outwards. Is this correct? Isn't it supposed to be blowing air into the discharger to cool it? Can someone clarify this for me. I don't want to melt my brand new discharger. Thanks.
29TC is offline   Reply With Quote
Old 10-30-2005, 11:05 PM   #8
loopedeloop's Avatar
Its meant to suck the air out
loopedeloop is offline   Reply With Quote
Old 10-30-2005, 11:07 PM   #9
The reason why its blowing air outwards is to draw or to blow to heat out from the unit.
It perfectly ok.
Ben.C is offline   Reply With Quote
Old 10-30-2005, 11:11 PM   #10
29TC's Avatar
Thanks for the fast response.
So is it safe to discharge a fully charged 3300 pack?
Old 10-30-2005, 11:17 PM   #11
It will get very hot from full charge, but you can rest it mid discharge.restart the discharge when it cools a bit.
Although I monitor the temps on mine, they seem to peak around 110-115 degrees
AMB Transponders,LRP PULSAR SPORT AND COMP,INTEGY 030 DISCHARGER,INTEGY TIRE TRUER NOTFASTENOUGH R/C Items: For Sale/Trade 10 06-19-2007 04:30 AM
Integy 0-30 Discharger DirtyDog3375 Australia For Sale/Trade 2 04-14-2006 08:02 AM
Integy V2 Dyno and NIB Integy Zero-Thirty Discharger. ridgewaybodies R/C Items: For Sale/Trade 24 11-27-2005 11:13 PM
integy 20/30 amp discharger hpipro321 R/C Items: Wanted to Buy 0 10-17-2005 01:49 PM
Wanted Integy Octane 2 Discharger or Trinity Realtime 2 Discharger FUK_WRX R/C Items: Wanted to Buy 0 08-02-2003 05:23 AM
