Old 10-15-2005, 08:40 PM   #46
geeunit1014's Avatar
Originally Posted by Brandon Melton
There is no messy compound soaked rags at day's end, and your hands aren't black stained.
But thats the bast part
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-27-2005, 12:50 AM   #47
thamjk's Avatar
Does all these traction compound prolong the run time apart from increasing the traction?
Serpent 710
Nova MAX
3PK
thamjk is offline   Reply With Quote
Old 10-27-2005, 08:37 AM   #48
Jeff Brown's Avatar
It really depends. I've tested SXT 1.0 on up to 10 run tires for modified. The last run was as fast as the first few runs.
I think the key to any sauce and helping used tires is baking something back into them.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 10-27-2005, 02:56 PM   #49
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Has anyone tried the old trick of putting the compound on the tires, then a paper towel over it, and then the tire warmer over it with SXT. I know it works with paragon but I am curious to see how it works with SXT.
TeamPink91 is offline   Reply With Quote
Old 10-27-2005, 06:08 PM   #50
Jeff Brown's Avatar
I know some guys that have had success in baking in SXT 1.0 (original). I am not sure if they used paper towels however. I believe they applied a second layer as well after about 15 minutes.
Jeff
Old 03-27-2006, 06:56 PM   #51
BringItOn's Avatar
hi. does red dot give off a strong odour?
thanks
BringItOn is offline   Reply With Quote
Old 03-27-2006, 07:46 PM   #52
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
i was woundering has anyone tried this stuff from corally called carpet jack? Juat to help you guys out a little... Q plus and paragon mixed together will kick some butt promise but only on foam tires on carpet that i saw this.
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 03-27-2006, 08:25 PM   #53
timmay70's Avatar
what's Q plus and who distributes it?
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 03-27-2006, 09:48 PM   #54
Super Moderator
Grizzbob's Avatar
thanks
Yes, Trinity's Red Dot is pretty much the same as Paragon's Ground Effects, though i think Red Dot has even more of the smelly stuff in it(tried some years ago, stuff was noxious, & I was even told the best thing to do was to mix it with Paragon or another weaker one so it'd decrease the chance the stuff would eat the glue on your tires)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-24-2006, 11:23 AM   #55
Is Death Grip Traction (Foam or Rubber) the so called Tyre Tweak? Cause I can't find it on trinity site. I can find tyre tweak for foam though, but dont want that one, I need the one for asphalt.
Geforcy is offline   Reply With Quote
Old 04-24-2006, 11:47 AM   #56
dstyles's Avatar
here you go:
http://www2.towerhobbies.com/cgi-bin...AK&FVPROFIL=++
dstyles is offline   Reply With Quote
Old 04-24-2006, 12:49 PM   #57
vabroom's Avatar
Originally Posted by Jeff Brown
Actually it does work on foam tires....... but on asphalt mainly. Coppertone 25 I think is the all time standby.
Jeff
It's true! We used to used on 1/8 nitro in the 80's and Delta also use it as an emergency shock oil.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 04-24-2006, 12:54 PM   #58
Tire Tweak is not the same as Death Grip.
Tweak is more of a conditioner you put on after some other tire dope to make the tire dope last longer.
The consistency of it reminds me of honey, you put it on (I use an old oil bottle) then you have to rub it in with your fingers. Its not like most traction compounds where you just use the dobber.
Red Dot is pretty potent smelling. Its not Wintergreen like Paragon, but more of just a strong chemical smell.
erock1331 is offline   Reply With Quote
Old 04-24-2006, 01:12 PM   #59
The summer season is going to start soon and i wonder, what should i use for our new Vtec-27R tires. As i have no experience with thouse on asphalt, have no ide with wath traction compound to go.
JanisK is offline   Reply With Quote
Old 04-24-2006, 03:19 PM   #60
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Great Planes/Tower Hobbies has Trinity Tire Tweak and Red Dot in stock all the time. My LHS has been getting in steady weakly shipments of both for many months.
Anthony.L is offline   Reply With Quote
Traction Compounds srs64 Electric On-Road 1 09-13-2007 04:25 PM
Tyre Traction compounds etc Got Xray? Australian Racing 29 08-13-2006 06:24 AM
Traction Compounds Questions DiegoVVRacing Electric On-Road 3 11-23-2004 02:14 AM
Chemical makeup of traction compounds? rcguy2477 Electric On-Road 9 06-17-2004 05:54 PM
what ingredients go into traction compounds ark Electric On-Road 0 05-05-2004 07:49 AM
