Old 10-11-2005, 08:12 PM   #1
anthony390's Avatar
Send a message via AIM to anthony390
Default Tire Tip & Tricks
hey i was wondering if tire aging is good or what
anthony390 is offline   Reply With Quote
Old 10-11-2005, 08:23 PM   #2
dakrat's Avatar
dakrat is offline   Reply With Quote
Old 10-11-2005, 08:24 PM   #3
I don't particularly like aged tires.IF the tires its the same brand and compound,a 1 year old NIP one will be inferior to a 1month old NIP.
As rubber age they tend to get harder.Harder means less grip....
So if you're buying tires...Get the freshess from the factory as possible
Ben.C is offline   Reply With Quote
Old 10-11-2005, 09:16 PM   #4
Jeff Brown's Avatar
Foam or Rubber tire?
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 10-12-2005, 05:48 PM   #5
anthony390's Avatar
any kind of rubber tire well ya if it does do age would it get more grip or what and will it last longer or what thanks
Old 10-12-2005, 06:01 PM   #6
koabich's Avatar
Send a message via Yahoo to koabich
I would like to help answer the question but...WOW...is that english? I cannot tell what you are asking. It might be beneficial to those you ask questions of if you used proper english and grammer. I can understand if you were foreign and did not speak english but dude, you are in Cali.
koabich is offline   Reply With Quote
Old 10-12-2005, 06:23 PM   #7
geeunit1014's Avatar
Jeff
both lose grip as they age
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-12-2005, 06:39 PM   #8
Jeff Brown's Avatar
I understand that..........
Aged foam tires are not necessarily bad because typically big races are High Grip so it keeps the car freed up. I'm saying like a year tops. Beyond that you run into dry rot issues.
Rubber tires are not usually too bad if they are kept in the original packaging.
Jeff
Old 10-12-2005, 07:01 PM   #9
anthony390's Avatar
sorry but i got my own answer already and thanks
What about making your rubber tires sit outside in the weather for about 2-3 days would it become harder
Old 10-14-2005, 11:42 AM   #10
Sushi Man's Avatar
Send a message via AIM to Sushi Man
whats the point of this> are you tring to make drift tires? yokomo already has good drifting tires...
Sushi Man is offline   Reply With Quote
Old 10-14-2005, 06:45 PM   #11
anthony390's Avatar
i know yokomo makes drift tires DUH.... anyways ya so the reason for this thread is so that people can get just the right custom compound that they need for there set-up on there car
Tricks??? jmdv Nitro Off-Road 5 12-18-2007 08:52 AM
tips and tricks kerry Electric Off-Road 8 01-28-2006 02:39 PM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
Up to my old tricks again........ GundamWZero Chat Lounge 2 09-09-2004 08:40 AM
esc tricks pro3racer Electric On-Road 6 02-27-2004 02:34 PM
