Getting back into 1/12 carpet racing
Hey guys, I raced 1/12 scale carpet years ago then took a long break and I have been racing USGT and USVTA touring car. I want to get back into 1/12 scale. What can you suggest for current chassis and electronics?
All the cars are good, can't go wrong with any of them. I would suggest CRC. The new car is great, parts are everywhere and it's cheap.
I have the RSD car RR12 and I have an XRay. The RSD car has a lot of steering and is a very fast car. It uses a lot of commonly made parts from Associated, Zenon front end parts etc. The XRay is a bit easier to drive but I have my RSD now driving very similar to the XRay. I honestly cannot say that either one is "better" but I sure do like a lot of things that Cristian has done with the RSD RR12. The Rear pod is nice, the front end has zero slop compared to the XRay and the body post are in a better position for most bodies. Xray put them right in the body line on the AMR 12 body and most of the other bodies as well. Another thing, the RSD car is lighter than the XRAY. Something else to consider too is that you can wear the tires down to the plastic on most wheels. My xray would always drag the chassis before I could get the most out of my tires.
^^^This... Find out what car most drivers are running at the local track, and start there. Once you feel you've "maxed out" your first choice, start evaluating another car, different electronics, etc... Chances are, you won't go wrong with any of the readily available cars on the market today.
Thanks for the tips guys, unfortunately there currently is no 1/12 scale class at the track. A handful of guys are trying to bring it back though.
As to electronics I suggest that you get an esc that supports 1S without the use of an external booster or rec pack. I'm using the Hobbywing V3.1 1S esc and it works well but there are several other choices out there. Get a short stack motor, a decent battery and servo (I like the 9650 myself), wire everything with 16g wire and your all set.
Also if you have not check the link in the Redbull's sig line, he has done alot of the leg work for everyone in that link.
