Roche Rapide P12 1/12 Competition Car Kit >
Like Tree168Likes
Old 09-13-2018, 04:55 PM
  #1321
thisguy2849's Avatar
Originally Posted by chris moore View Post
All of the setup sheets in your link at Roche USA end at Jan of 2016, are there additional setup sheets (besides the one Donny posted) anywhere else?
check petiterc
thisguy2849 is offline
Old 09-13-2018, 05:01 PM
  #1322
Trader Rating: 46 (100%+)
Originally Posted by robbie_gtc View Post
Look for a good starting 17.5t setup for the 17 usa spec. was told the kit setup is more of a mod setup.
track is black carpet med-high grip on new layout.
Post #1255 in this thread.
biz77 is online now
Old 09-13-2018, 05:38 PM
  #1323
Trader Rating: 18 (100%+)
https://drive.google.com/drive/mobil...lU?usp=sharing
iTz Nicholas72 is offline
Old 09-13-2018, 08:53 PM
  #1324
chris moore's Avatar
Trader Rating: 92 (99%+)
Thank you gents, I was looking for some 17.5 setups for the 16 model and I was able to find a couple more between those two.
chris moore is offline
Old 09-13-2018, 10:10 PM
  #1325
hanulec's Avatar
Trader Rating: 27 (100%+)
The setup difference between 2016 and 2017 is near zero
Biggest points of change is rug rype and spool or no spool
hanulec is offline
Old 09-14-2018, 06:59 PM
  #1326
Good to know Mike, I'll take a look at those for reference also.
Old 09-25-2018, 06:24 PM
  #1327
Hello. Just got my new spool. Of course I failed to read the small print that you need another left hub. And of course they are now sold out everywhere as well. What is everyone using? The Associated looks quite similar. Any ideas? Thank you
quertreiber is offline
Old 09-25-2018, 07:29 PM
  #1328
Genesis RC Raceway sells Roche parts and has the item you need in stock. I have not measured an AE clamping hub but I'm sure you would be just fine using one.
Old 09-25-2018, 08:34 PM
  #1329
hanulec's Avatar
Any left hub will work. Just need to shim accordingly.
hanulec is offline
Old 09-25-2018, 09:09 PM
  #1330
Thanks. I saw the one at Genesis RC. But I'm in Canada and shipping makes this unreasonably expensive. I will try the AE hub. My local hs has one.
Old 10-01-2018, 06:05 PM
  #1331
Samwise's Avatar
Has anyone tried this for Mod 12th scale? Thoughts?
http://www.rocherc.com/index.php?route=product/product&product_id=785
Samwise is offline
Old 10-02-2018, 08:38 AM
  #1332
Trader Rating: 38 (100%+)
Does anyone know if these work/fit for the Roche cars?
https://www.tqrcracing.com/shop/prod...asp?p_id=13420
Nexus is offline
Old 10-02-2018, 09:22 AM
  #1333
hanulec's Avatar
Nope
Wrong drill pattern
​​​​​​R5 is the same drill pattern
hanulec is offline
Old 10-02-2018, 04:46 PM
  #1334
the ride height Shims for the VBC 12th scale work great
magnum is offline
Old 10-07-2018, 08:44 PM
  #1335
Will the front suspension bulkheads for a 17 car bolt onto a 15/16, is the spacing on the chassis the same? Thanks
magnum is offline
