Old 10-18-2005, 11:51 PM   #16
Red RSX's Avatar
Originally Posted by asw7576
I don't know what happen with my car....... It glitches to full throttle The full throttle glitch ONLY exist during the first 1 minute playing ( I guess it only glitch when the battery is full ).
My ESC is LRP QC2 and Receiver Futaba PCM R113ip. My receiver is insulated by alluminium foil on the side, bottom and underneath. All equipments are new.
I also have insulated the wire antenna with heat shrink tube at location where the antenna wire touch the graphite. I suspect either the Rcvr or LRP QC2 is the culprit Please see the photo for examination.
What do you suggest ?
Ups forgot one thing,
4th, if 1-3 all OK, try to take out fan socket out of receiver,
its possibly the brushless fan operating pulse feed interference back into receiver, one my friend ever have such this glitch due to the brushless fan,
Red RSX is offline   Reply With Quote
Old 10-19-2005, 12:03 AM   #17
asw7576's Avatar
I place the laminated alluminium foils inside the receiver box for aesthetic reasons. I'm sure nothing wrong with the foils.
It's either electronics components inside esc or receiver that makes glitch problem.
Or maybe the brushless fan !!! thanks for pointing that out
Old 10-19-2005, 12:15 AM   #18
Red RSX's Avatar
It's either electronics components in esc or receiver that makes glitch problem.
inside receiver? wow.. how brave you...
I dunno its if its foil conductor aluminum or not (blue aluminum anodizing BD parts surface can't conduct electricity..) but its better to check it out by continutiy test using multimeter on foil material
normally some people put wrap on external receiver casing (from Kimihiko yano website..)
Old 10-19-2005, 12:32 AM   #19
asw7576's Avatar
Don't worry, I laminated the foil first, so it doesn't short circuit with electronics components.
Old 10-19-2005, 08:39 AM   #20
Regional Moderator
daniz24's Avatar
First thing first.... Never install your receiver near the motor or touch anything, especially the ESC.
daniz24 is offline   Reply With Quote
Help please with interference Wing Chun Electric On-Road 26 02-22-2007 08:37 PM
interference help riley1131 Electric On-Road 11 01-21-2007 11:21 AM
Interference makytc4 Electric On-Road 5 06-11-2006 05:17 AM
Interference please help Mr-s413bt Australian Racing 17 05-04-2004 10:43 PM
