Old 10-10-2005, 02:13 PM   #16
Send a message via AIM to R/C Anonymous
i have always had experience that if you lay your shocks down more you get more side bite
for instance: if your cars back is loose and you lay the shocks down one hole then it wont be as loose
going into a turn when you need more inturn steering you can lay your shocks down a little more to gain it
but theres always other ways to change this also
R/C Anonymous is offline   Reply With Quote
Old 10-10-2005, 02:13 PM   #17
josh69162's Avatar
Send a message via AIM to josh69162
If the Hudy book doesn't satisfy you, check out the XXX-Main chassis guide book. It's because (according to the book, which I agree with) the full spring's power is split between the X (horizontal) and Y (vertical) axis. Since the suspension travels on the Y axis, having a shock more parallel to that axis puts more of the shock's power on that axis. For a real life example, take a really heavy box, and push straight into it. Your arm is the spring. Now push up into the box at an angle. Which is easier to move the box? Since your power is being relieved straight into the box, there is more force pushing the box foreward, rather than trying to push it up and foreward.
-Josh
Last edited by josh69162; 10-10-2005 at 02:15 PM. Reason: grammar and box example added
josh69162 is offline   Reply With Quote
Old 10-10-2005, 02:54 PM   #18
teamgp's Avatar
Thanks josh.
Sam,
Laying down your rear shocks will give you less grip if you don't have enough rear droop or have too much front droop. The softer rear suspension can allow the car to roll more causing the inside rear wheel will to lift off the track, overload the outside wheel and end up with abrupt loss of rear traction.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-10-2005, 04:50 PM   #19
Sam_Smith's Avatar
Send a message via MSN to Sam_Smith
Maybe I am wrong http://home.tiscali.be/be067749/58/c2/index.htm
Sam_Smith is offline   Reply With Quote
Old 10-10-2005, 05:01 PM   #20
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by teamgp
Thanks josh.
Sam,
A lot of people call this "dumping over." Most of the time, it's thought that a softer suspension will give more grip, but you have to adjust the rest of the car to accommodate it.
And what was said about the laid down shock being more progressive is dead on.
Jon Kerr is offline   Reply With Quote
Old 10-10-2005, 08:00 PM   #21
newera152's Avatar
The problem im having is with traction the back slides alot im going to try the setup you guys are speaking on as a starting point, the problem i hav is which shocks to use foam tires to us i just get out there are race I'll take any info I can get web site to check. TALK TO ME!
newera152
newera152 is offline   Reply With Quote
Old 10-11-2005, 05:40 AM   #22
Thats why you yanks are so slow
Joking but what to say that that website you posted is credable Sam?
HardcoreRC is offline   Reply With Quote
Old 10-11-2005, 05:48 AM   #23
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
What is on that website used to be on the Team Orion site a while back. Its pretty good if you can soak it all in. Helped me in learning to set a car up properly.
dontfeelcold is offline   Reply With Quote
Old 10-11-2005, 10:08 AM   #24
teamgp's Avatar
Same here. I read it awhile back and it helped a lot.
Guy Hood
Old 10-11-2005, 10:48 AM   #25
newera152's Avatar
whats the web site that helped you guys .
Old 10-11-2005, 01:08 PM   #26
teamgp's Avatar
Sam's post above has it.
Guy Hood
Old 10-13-2005, 09:55 AM   #27
newera152's Avatar
sams site is go info.any other site I can use on tuning the car.
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 01:04 PM
Adjustable Positioning Adapter for 3PK Syndicate Australia Wanted to Buy 0 03-07-2006 02:34 AM
positioning the esc HELLOkitty Electric On-Road 5 12-20-2005 03:26 PM
TC3 FT aluminum shock tops w/Lunsford "quick tune" shock mounts? billwilner Electric On-Road 2 01-06-2005 08:49 PM
NTC3 Shock and Team Associated Shock Caps Question jcrouse Nitro On-Road 4 07-13-2003 10:11 PM
