Old 10-05-2005, 04:26 PM   #1
Jeel's Avatar
Trader Rating: 16 (100%+)
Default Foam tire wear...front to rear
My TC4 FT sedan is setup for stock on carpet and I run double pink rear, double pink/orange fronts. I am running the baseline setup for carpet that came with the kit. My problem is that I keep going through front foams at a MUCH faster rate than rears...is this common? I start my foams at 58mm and I am averaging 15-20 packs of life on the fronts (down to rim) while the rears are still hovering around 57mm.
Any suggestions and/or insight?
Jeel is offline   Reply With Quote
Old 10-05-2005, 04:41 PM   #2
Trader Rating: 18 (100%+)
I experienced the same thing last weekend (2mm wear in front and .5mm wear at the rear) and I attribute it to the "Push" that comes with that particular set up. I am going to try some different things this weekend to cure it.
Step one will be take off the sway bar. Step two will be turn down my dual rate. 85% or less should be good. We will see from there. Good luck...
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-05-2005, 04:55 PM   #3
timmay70's Avatar
Justin, the problem is the fact that you keep trying to mix your dirt driving style and your carpet driving style. You need to drag Matt up on Tuesday nights and bring your carpet cars and learn the way of the lint gods while we all bask in the curing aroma-theropy<sp?> of Paragon.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-05-2005, 05:23 PM   #4
Try purple/orange fronts. They may last a little longer.
Jack Rimer is offline   Reply With Quote
Old 10-05-2005, 06:44 PM   #5
Jeel's Avatar
Hey Tim, put your sedan down with me and McCready and we'll consider it. Muuuaaaaa!
Old 10-05-2005, 09:05 PM   #6
teamgp's Avatar
I'm not familiar with the TC4 FT, but if the weight distribution is front heavy (like the FK05) and/or you run a stiff front end setup, then the front tires will be worked harder for traction and wear more. Its actually not a bad thing ($$$ withstanding) concerning performance if the car's front end is glued in the corners and not pushing on or off power.
With my current FK05 setup and running purple/orange fronts and double pink rears, my fronts are wearing .1mm more per run. But the front is stuck like George Jefferson under Nel Carter.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-06-2005, 01:32 PM   #7
stiltskin's Avatar
Trader Rating: 102 (100%+)
I'm sure his front will wear out faster than her rear also.
Sorry guys, couldn't resist.
stiltskin is offline   Reply With Quote
Old 10-06-2005, 01:44 PM   #8
thecrow2k's Avatar
The easiest thing is to use a harder spring, thats the only advice I can give.
thecrow2k is offline   Reply With Quote
Old 10-08-2005, 12:36 PM   #9
geeunit1014's Avatar
naturally no matter what unless your drifting in every corner, the 4wd nature of the car will cause the tires to wear more in the front, you just have to keep ride height in check (f/r).
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Left front Tire wear sachoppers Nitro Off-Road 23 07-26-2008 07:28 PM
LOSI 2.2 truck tire lot front and rear garrettsdad R/C Items: For Sale/Trade 4 06-12-2007 06:33 PM
Is Even Foam Tire Wear a Sign of Proper Setup? SlamMan Electric On-Road 14 02-20-2007 04:10 PM
DuraTrax Foam Tire/Wheel Mounted Front & Rear Green F1 (4) Jeff Shriver R/C Items: For Sale/Trade 1 02-11-2006 10:08 AM
new paragon 12th front and rear positrak tire on new white yokomo rims jason cheng R/C Items: For Sale/Trade 4 05-03-2003 03:39 PM
