Old 10-04-2005, 03:04 PM   #1
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default JRXS SHOCKS OR TRF SHOCKS
Who makes the best shocks out there?
I am looking for a consistent shock that is not to painful to build.
Will I mess up the geometry of the suspension by using different brands of shocks (Losi or Tamiya shocks) on a FT TC4 ?
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-04-2005, 03:20 PM   #2
polesitter61's Avatar
I just put a set of TRF shocks on my FK 05 for this past weekend for the race at superior and they worked perfectly, very easy to build and bleed, and the car felt better than ever. Just my 2 cents.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 10-04-2005, 03:38 PM   #3
Default Thanks
Thanks POLESITTER61 for your input!!!!!!!
O-TOWN, FLA.
Regards,
E
Old 10-04-2005, 03:43 PM   #4
OSherman's Avatar
I would have to go for the new LOSI shocks.. Great to build, very smooth..
Also the knurled surfaces make it very easy to tighten the caps down.. And their some-what neutral color goes with almost any other color of anodizing out there.
O-Show
from O-side, Cali.
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 10-04-2005, 03:43 PM   #5
gatrbite's Avatar
Send a message via AIM to gatrbite
I've had both. My choice: TRF
Jeff Mohn
Studio 14 Photography www.studio14photos.com
Bumps and Jumps RC www.bumpsandjumpsrc.com
gatrbite is offline   Reply With Quote
Old 10-04-2005, 03:45 PM   #6
RCknight's Avatar
Default Never used the Tamiya ones, but all I can say is that
the JRX-S shocks are great! Only down side is that they are expensive to part together. Losi does not offer kits yet. Great detail and they are very, very, smooth and you have the option of using 1-2 o-rings. I have not had to rebuild mine yet after four months of racing. They are also a direct fit and the Losi springs work great for carpet on the TC4.
RCknight is offline   Reply With Quote
Old 10-04-2005, 03:54 PM   #7
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
TRF all the way. Both shocks are high quality.. BUT.. and this is a HUGE but.... TRF shocks can accomodate almost every other spring, even corrally (i have them on my RDX)
Losi shocks, only losi springs...
I have a brand new set of rdx shocks id sell ya cheap.. i just wanted blue shocks (trf)... rdx shocks are very good as well..
pm me if interest.. im unemployed... I MEAN CHEEP!!
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 10-04-2005, 04:11 PM   #8
Default Corally shocks
No thanks on the Corally shocks.
Yes the TRF shocks can use multiple brands of springs.
But I think Losi springs are one of the cheapest along with AE on the price of there spring kits.
Also I am not into to all of the different colors from different manufactures of spring.
I like the Losi springs concept that all of there springs are the same color and that each spring is tagged with the spring rate.
So I think I have made up my mind.
I am going to go with the Losi JRX shocks.
Thanks for your time and input.....................................
Later,
E
Old 10-04-2005, 04:14 PM   #9
Matt Howard's Avatar
just put the Yokomo bladder caps on your TC4 shocks and they'll be alot better and cheaper than buying 4 new shocks
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-04-2005, 04:17 PM   #10
AM03GT's Avatar
"I always run rebound, @ 3/4ths travel. We do have new shock caps coming out with bladders, that will offer adjustable rebound. I have them but have not tried them yet. that is the next step for me."
from the TC4 forum...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 10-04-2005, 04:27 PM   #11
koabich's Avatar
Send a message via Yahoo to koabich
Haven't messed with the new Losi shocks. I must admit Tamiya shocks are great but why don't you just stick with the Associated shocks? Once built, they are every bit as good as the TRF shocks. Sure they take a little bit more fussing to bleed but once done, they are perfect. If you are compentent enough to build a car, the 4 Associated shocks will take you maybe 5-10 minutes longer to build than 4 Tamiya.
And anyone that says that Associated shocks need to be rebuilt more often than Tamiya (or any other brand for that matter) has no experience with them or didn't build them correctly to begin with.
Spend the extra $50-$60.00 you'd otherwise spend on the Tamiya shocks and buy something that is necessary to spend it on...like batteries, motors, bodies, spare parts, etc.
koabich is offline   Reply With Quote
Old 10-04-2005, 04:48 PM   #12
BlackKat's Avatar
I've tried the Associated shocks, Yokomo shocks and the TRF's on my old TC3 and current TC4. I'm currently running the TRFs for setup purposes (I have all the different pistons) The Yokomo shocks seem very nice too, they seem just like the TRF's in terms for rebuilding & quality
The Associated work good too but I find need to be rebuilt more often than TRF or Yokomo shocks. If I didn't already have the TRF shocks I'd probably have just bought some Yokomo bladder-caps for the stock Associated shocks
BlackKat is offline   Reply With Quote
Old 10-04-2005, 07:52 PM   #13
RCknight's Avatar
Default AE shocks will take much longer, I'll never use...
them again. The inside retainer will sometimes come apart and they will leak even if you get the Yoke caps. You can never get them to rebound the same after many attempts. Life was easier when I went to Losi shocks. Much easier. Everyone's starting to go to a screw on bottom for o-rings. Way better.
Old 10-04-2005, 08:52 PM   #14
GReddy's Avatar
Send a message via AIM to GReddy
im using trf shocks and i cant say that theres anytihng wrong with them
GReddy is offline   Reply With Quote
Old 10-04-2005, 08:56 PM   #15
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Go with tamiya's or just stick with the stock ones and buy the Yokomo shock cap and bladder.
Roberto Falcon is offline   Reply With Quote
WTB...XX4 shocks/ JRXS TYPE R metalracer2 R/C Items: Wanted to Buy 3 06-13-2008 08:47 PM
WTB IRC Shocks Or Losi After Shocks Or LS2 Shocks !jAsOfRaW! Australia Wanted to Buy 0 01-25-2008 02:12 AM
WTB: RDX,JRXS,TRF (GUN METAL) SHOCKS RED-LINE M03 R/C Items: Wanted to Buy 1 11-06-2005 05:56 PM
WTB JRXS SHOCKS RED-LINE M03 R/C Items: Wanted to Buy 0 10-25-2005 04:59 PM
wtb: 1/8 rear buggy shocks or t-maxx size shocks arawak420 R/C Items: Wanted to Buy 0 05-23-2005 07:05 PM
