Old 10-03-2005, 02:40 PM   #16
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Well I already do have saddle, and I have a tray.
About the chassis, I have a old Tamiya Evo 3. What shiuld I do to Make the batteries fit> (the gp3700) ?
Sushi Man is offline   Reply With Quote
Old 10-03-2005, 03:05 PM   #17
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Someone mentioned before, grind away. If you can't get a chassis for that car that's made to fit the larger cells like you can for most cars out there, you'll need to make some modifications yourself to make them fit.
Jon Kerr is offline   Reply With Quote
Old 10-03-2005, 03:34 PM   #18
Sushi Man's Avatar
Thanks everyone for your help. I will try to file and grind the chassis out so i can fit the batteries
Old 10-03-2005, 05:18 PM   #19
Super Moderator
Grizzbob's Avatar
Exactly, that's what I had to do when I bought my FT TC4, before I started building it. I had to use my Dremel rotory tool to grind away enough chassis material in the right places so that the battery slots would accept both GP3700 & GP3300 cells(they are spaced right on the FT TC4 for the 3700's, but not for 3300's, so I had to work on that to get all to fit properly & of course to make sure the chassis won't ever cut into the cells' shrink wrap in a crash, smoothed everything out properly). I know that if you don't already have something like a Dremel it might seem a bit expensive just to use with your R/C stuff(I've seen prices for them anywhere from $35 to $120 depending on how powerful it is & how many features & bits come with it) but I guarantee it's a tool you'll never regret buying, they have uses for EVERYTHING, it's something every man should have in his toolbox....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 10-13-2005, 08:37 AM   #20
Suspended
GordonFreeman's Avatar
Just to clarify a saddle pack is a split 6 cell (like the TK04). A stick pack is a 6 cell pack with 2 rows of 3 cells end to end. Normal racers use the side pack assembly so you can equalize each cell.
Suprizingly the lowest resistance packs are made "stick style" end to end by direct soldering the cells together, therefore eliminating 4 battery bars. But there are no sedans built to accept stick packs properly.
We are the borg, you will conform, you will be assimilated. You will not stalk me to another web site.
GordonFreeman is offline   Reply With Quote
Old 10-14-2005, 11:22 AM   #21
Sushi Man's Avatar
yes i was confused when a post on this thread by someone explain that if you use high quality bar you have less resistance but on a stick the one place you use it is at the bottom of the stick pack, other wise the cells are direct and no bars. But yea unless someone want to put together a stick pack every time after they equiliuze, condition it and make your chassis able to fit a stick pack properly and be able to have low center a gravity..... Yes saddle is easier in that way i guess
Old 10-14-2005, 01:17 PM   #22
josh69162's Avatar
Send a message via AIM to josh69162
Actually, unless you have the rig to solder cell to cell, stick packs have more resistance. They use a cheap, sheet metal type of battery bar, assemble three cells like a side by side, and then just fold the cells over end to end. There was a video on making battery packs that showed a rig on assembling the cells directly, end to end. It's actually pretty interesting, but I can't find it. Maybe someone else can.
-Josh
josh69162 is offline   Reply With Quote
Old 10-14-2005, 08:33 PM   #23
geeunit1014's Avatar
at my lhs we make sticks for micros by strait soldering the cells together with only 1 bar at the end. we just heat the solder and shove 'em togheter before it cools. is a pain in the arse to biuld, but low resistance
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-14-2005, 08:43 PM   #24
lost
Guest
Posts: n/a
but how do u break apart the cells to troubleshoot them when one of the cells seems shorted ?
Old 10-14-2005, 10:33 PM   #25
Red RSX's Avatar
Originally Posted by Piyo Piyo
Proper discharge have 2 steps. 1. Discharge to 5.4 V for the pack. 2. Equalize each cells individually. Well, at least it will keep your battery performance. And no way for a stick pack cells to be equalized individually.
there's a way Piyo Piyo..
Never seen this..
Red RSX is offline   Reply With Quote
Old 10-15-2005, 12:16 AM   #26
Sushi Man's Avatar
haha smart, I guess thatgadget solves that
Old 10-15-2005, 05:51 AM   #27
is300zx's Avatar
Send a message via Yahoo to is300zx
To solder end to end battery packs you'll need a hammerhead tip for your soldering iron. I bought mine at www.cheapbatterypacks.com. It also works great for side to side battery packs and it'll last much longer compared to the regular weller chisel tips. And here's a video of how to make end to end stick packs using the hammerhead tip. http://norbique.rchomepage.com/video...g_complete.avi
is300zx is offline   Reply With Quote
Old 10-15-2005, 07:44 AM   #28
with your hands go *snap* and break the solder
Mike Gee
Old 10-15-2005, 09:08 AM   #29
Jon Kerr's Avatar
I don't understand why anyone would want to run stick packs. You have to go through the extra work to get a special iron tip and make special discharge trays. Cars are designed for side by side, they sit lower in the car, there's already ton's of equipment there to maintain them, and they're much easier to build. I did three packs last night in less than 10 minutes.
Old 10-16-2005, 10:03 PM   #30
ChadCapece's Avatar
B/C if you can solder up a stick pack, then you can cheat in a spec class. Rewrap the cells with the spec labels and you could build a stick pack out of matched cells or higher mah cells. Dirty trick, and sadly, some will do anything to win a club race that is supposed to be "spec"
ChadCapece is offline   Reply With Quote
Matched packs! 6 Cell flat, saddle, and stick. Very little use. BADAZZPSD R/C Items: For Sale/Trade 12 06-16-2008 01:18 PM
Max Amps 6000 stick and 4400 saddle pack Kingsbury R/C Items: For Sale/Trade 14 11-02-2007 12:26 PM
converting a stick only chassis to a saddle greencactus3 Electric On-Road 5 02-01-2005 01:38 PM
stick to saddle packs h22ah Electric On-Road 5 01-15-2004 12:53 PM
