Old 10-01-2005, 07:32 AM   #1
Deeds's Avatar
Default Simple GFX 35 Question..
I thumbed thru the manual then got a little lazy...When cycling a battery can you set a delay between the charge and discharge? I know you can set a delay between cycles...but can you do it in the middle of a cycle? If you can't...why is that? The battery is pushing 125 degrees after the charge...then discharging at 30A really could roast a pack.
Deeds is offline   Reply With Quote
Old 10-01-2005, 08:01 AM   #2
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Check out the expanded new manual.
http://www.competitionelectronics.com/GFX.html
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-01-2005, 12:49 PM   #3
jamescam's Avatar
On my T35 Stealth the time between charge & discharge is 15 seconds and can't be increased. I suggest you get a mini-fan and point it directly at the cycling pack.
jamescam is offline   Reply With Quote
Old 10-01-2005, 08:50 PM   #4
Still Bill's Avatar
If you were running that charged pack and timed everything right, it would be starting its discharge at that 125 degree temp anyway. Therefore, I don't see any problem.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-01-2005, 09:11 PM   #5
koabich's Avatar
Send a message via Yahoo to koabich
JRX-Bill is correct. Besides, I wouldn't recommend putting a fan on NimH cells when either charging or discharging as these celss perform better when 125-140 degrees. Putting a fan on them could effect their numbers.
koabich is offline   Reply With Quote
Old 11-08-2005, 08:08 PM   #6
danjoy25's Avatar
Trader Rating: 37 (100%+)
Just about to fork out on a as new GFX and would like to know the latest version software it should have or there is no such thing. Would also $325.00 shipped overseas sound reasonable?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-08-2005, 08:27 PM   #7
Tres's Avatar
Current software version is 1.60 (variable motor run upgrade, adjust the voltage while the motor is running).
Tre's
www.tnt-fx.com
Simple Question about Brushless Elboogie Electric On-Road 3 05-23-2007 11:06 AM
simple question about spektrum PLANETSTEREO Electric Off-Road 13 02-18-2006 11:22 AM
Simple Question Viper212 Rookie Zone 2 04-20-2005 06:34 AM
Very simple question about my batteries! reznikvova Electric On-Road 3 08-21-2004 03:57 AM
Simple Orion V2 Question Cain Electric On-Road 38 08-06-2004 08:12 AM
