Old 10-01-2005, 06:31 AM   #1
Default Unable get full 300mah
Can you guys help me my New Power Pack battery RC-3000 can get fully mah the most it can get is 6XXmah my setting is as below
Power Pack RC-3000 stick packs:
Charge try at 4A,5A and 6A charge
20A discharge setting
try from zero peak to 8mv Cell delta peak
50C cut off temp
<Linear> charge mode
Max charge capacity at 110%
With those few setting the most it can get is 6XX mah.
I try discharge it at 20A and stop at ard 30mah.Should use my wall plug charger and charge it overnight.
I am using supernova Comp charger.
X1 CRT
KO HELIOS
9351,9451
STS.28
JP3
JConcepts
faiunie is offline   Reply With Quote
Old 10-01-2005, 06:51 AM   #2
Joel Lagace's Avatar
try 12mv per cell. The sanyo 3000 at the time used a higher delta peak setting much the same as the 2400nicad used. Only the panosonics in the 3000 range used much much lower deltas.
I your charger has a lock out feature use it. But make sure to discharge just before charging with the lockout.
600mah sounds like a faulse peak and that could be from a low delta peak setting. It shouldnt really have issues at 8mv but i do recall using 12mv back in the day.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-01-2005, 09:09 AM   #3
Thanks bro for the suggestion.But am I gonna use the lock out feature .At which setting to set at lockout.
X1 CRT
KO HELIOS
9351,9451
STS.28
JP3
JConcepts
Need Help....unable to keep engine running Sheazy0219 Onroad Nitro Engine Zone 2 06-26-2004 12:53 PM
Full on!!! teamsherman Australian Racing 1 04-20-2003 09:02 PM
90% new V-One RR with full hop-ups Diva R/C Items: For Sale/Trade 14 08-13-2002 09:12 AM
unable to post in sydney thread? ozzyNEOdriver Australian Racing 10 12-05-2001 01:03 PM
