Castor Question? >
Castor Question?
Castor Question?
Old 10-07-2001, 08:06 PM
che
che's Avatar
Castor Question?
Okay, this may not be an easy question to answer but here it goes:
Keep in mind with all else being equal and the fact that you found a good base setup. Running on a tight high bite indoor carpet track.
What would the effect have if the ONLY thing I chaged was the amount of front castor? Say I went from 7deg to 5deg...
Does it make that much of a difference? If so would more or less be more beneficial? Again, small, tight, grippy carpet track with foam tires (or does it matter track size and bite?).
Thanks,
Che
che is offline
Old 10-07-2001, 08:19 PM
Core Creations's Avatar
Trader Rating: 105 (100%+)
I believe it would give you a little more agressive initial turn in?
Core Creations is offline
Old 10-07-2001, 08:46 PM
dtm
dtm's Avatar
More Caster 7 deg - Less off power turn (initial), more on-power turn
Less Caster 5 deg - More off power turn (initial), less on-power turn.
It depends on how "in-tuned" you are with the car has to whether to will notice a 2 deg change in caster. I certainly can with my Xray!
dtm is offline
Old 10-07-2001, 08:57 PM
Moderator
Speedo's Avatar
The effect of more casor is raising the front end more when you turn the wheels. I downloaded the X-ray tuning guide, and it states:
Less Castor (more vertical) increases OFF-power steering INTO a corner, but decreases straight-line stability.
More Castor (more laid-down) increases ON-POWER steering OUT OF a corner, and increases straight-line stabilty, but makes the car harder to turn in.
Josh
Speedo is offline
Old 10-07-2001, 10:39 PM
robk's Avatar
Trader Rating: 22 (100%+)
Think of more caster as adding high speed steering and less as adding low speed steering. Low speed=slowing down for the 180* turn. High speed = thru the sweeper. This helped me to figure it out a little better.
robk is offline
Old 10-07-2001, 11:56 PM
dtm
dtm's Avatar
Josh
Wasn't that what I said??!
dtm is offline
Old 10-08-2001, 02:21 AM
Cole Trickle's Avatar
Thanks guys, you gave me an idea: How about using less castor combined with a body like Alfa 156?
Then the initial off-power steering is great and since the body dominates at higher speeds, the Alfa give the good high-speed turning? Sounds like the only thing missing is on-power steering going out of a slow speed turn like a hairpin?
Any comments?
Cole Trickle is offline
Old 04-26-2011, 11:08 PM
chubbspeterson's Avatar
I think it also helps in the 180's once your in the turn more castor gives you more wrap....
took me a while to get an answer, but I think I got it.
chubbspeterson is offline
Old 04-26-2011, 11:11 PM
robk's Avatar
I was just thinking about this. Thanks.
robk is offline
