Old 09-29-2005, 02:09 PM   #1
Trader Rating: 13 (89%+)
Default Best TC for Rubber Tire Carpet Racing
Which is the best (everyones opinion welcoms) Xray t1-05 or HB Cyclone or Tamiya 415 Associated Factory TC4??????
rcscrewz is offline   Reply With Quote
Old 09-29-2005, 02:15 PM   #2
Charles Godwin's Avatar
A car which is set up well , personally i recon a FK05 as i drive one but others cars like tamiya and corally seem to be doing well also the JRXS
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 09-29-2005, 02:19 PM   #3
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
So many great cars.........What an intresting dilema.
Let your wallet run free!!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 09-29-2005, 02:20 PM   #4
thecrow2k's Avatar
Jeez, must be the what, 6000th topic on the same subject matter, use the search button.
thecrow2k is offline   Reply With Quote
Old 09-29-2005, 02:31 PM   #5
bighurt98's Avatar
Default Best Touring car for rubber tires???
All of the top cars are great. Odds are you will never be able to push the car to the limits that make one of these cars better than the other. Only the very best drivers do this so any of the cars from this list:
Xray FK05
Tamiya 415MSX
Tamiya Evo 4
Losi JRXS
Corally RDX
Schumacher MI2
HPI Pro 4 Hara Ed.
HB Cyclone
AE TC4
These are expensive cars, so you can try lesser value cars that are great and won't break you.
Tamiya TA05
Xray FK04
AE TC3
Losi XXX-S
HPI Pro 3 or 4
Tamiya 414 MII
Tamiya Evo 3 Surk
Some of these are older models, but are solid cars.
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 09-29-2005, 03:06 PM   #6
Trader Rating: 14 (100%+)
Keith:
Get me a 05 and a 3mm chassis/top deck and stand offs and you can have my RDX. you know it's fast on rubbers.
(we race nothing but foams now)
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 09-29-2005, 05:39 PM   #7
BlackKat's Avatar
For rubber carpet I tried about everything out there (I run rubber-carpet exclusively) I'm sticking with my TC4 man! The Pro4 is a great car too but I had problems with drivetrain durability. I prefer not to comment on the XRay '04 though
BlackKat is offline   Reply With Quote
Old 09-29-2005, 05:47 PM   #8
nashrcracer's Avatar
R/C Tech Charter Subscriber
Tamiya 415MSX was designed for rubber tyre. the rest can be set up for it but are mostly made for the amercian foam market. the tamiya comes with a spool or oneway I forget which one. and you have to get the multi diff for the xray if you buy it in the states. I'm not 100% sure on that though. and associated and hpi come with diffs so you have to buy something extra would make me think it's not intended for a rubber tyre market. as with the tamiya you have to get a yok from diff and shim it to run foam with it which would make it a bad choice for foam.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 09-29-2005, 05:50 PM   #9
Let me add my .02 cents. Buy the Yokomo BD; it's great on carpet and rubber tires.
kmorast is offline   Reply With Quote
Old 09-29-2005, 09:17 PM   #10
ChadCapece's Avatar
most def, Yokomo builds cars for rubber tire racing. LCG and BD are two cars SPECIFICALLY designed for asphalt or rubber on carpet. JRX-S is too stiff as of now (I've heard they are making new parts to soften up the suspension). Schumacher looks like a really smooth car on the track. Pro4 Hara is also designed for rubber tire racing. And I can't comment on the others.
ChadCapece is offline   Reply With Quote
Old 09-29-2005, 09:37 PM   #11
Trader Rating: 37 (100%+)
nash......note the hpi pro4 comes with a oneway and IMO it's more designed with rubber tire racing in mind.....as are most asian rice burning cars :P
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 09-29-2005, 09:45 PM   #12
ChadCapece's Avatar
Yokomo, HPI, Tamiya do seem to design their cars soley for rubber. Probably b/c asia and europe race alot of rubber on carpet and asphalt.
Old 09-29-2005, 10:57 PM   #13
Registered User
xrcbuggy's Avatar
Got burned by HB, never again will get close to any HB products. Check it for yourself, go to thier site & look around for parts & tech. inf on thier cars. You want a good car with part & tech support then go for Yokomo, Mugen, Xraay & HPI.
xrcbuggy is offline   Reply With Quote
Old 09-30-2005, 12:21 AM   #14
I think you can go check out the results of the recent IIC.
The foam mod was won by Marc Rheinard on a 415MSX,so the notion of 415 is only design for rubber is not true.
The rubber mod was won by Atsushi Hara using the cyclone.
So all car are good.But still depends a lot on the driver.We are not on the same level as Marc and Hara,where thecar really does matters.
Ben.C is offline   Reply With Quote
Old 09-30-2005, 05:36 AM   #15
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Ben.C - I was talking with the Tech crew from the IIC. Marcs 415 was basicly a one off car. It had a huge 3.5+ mill chassis with areas for the bulk head shaved.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Rubber Tire Carpet Setup Differences dr_hfuhuhurr Electric On-Road 16 10-12-2006 02:35 PM
Best touring car for rubber tire on carpet racing? rccars4scott Electric On-Road 0 09-18-2006 04:55 PM
JRXS Rubber Tire Carpet Setup? rcscrewz Electric On-Road 9 01-03-2006 01:13 PM
Rubber Tire - Best TC for Carpet rcscrewz Electric On-Road 10 12-20-2005 07:45 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
