Old 10-09-2002, 08:50 AM   #16
RC Nitro's Avatar
Thanks for the info and link. Looks promissing on the new unit. Could you post the new spec's?
RC Nitro is offline   Reply With Quote
Old 10-09-2002, 10:01 AM   #17
RC Nitro's Avatar
Troy: I just got off the phone with Jim @CE was having a false peaking problem on the T35 when I start my tire truer. On the new unit Feb release. As I want a second unit for racing and B-Day is March........ Bet the wife hits me
Old 10-09-2002, 02:38 PM   #18
i asked when the gfx would be out on the charger forum and a guys on there heard from jim at ce that it would be out in february but he did not mention the price, do any of you guys have any info on the price. i cant wait till february to get mine.
Jarrod Langlois is offline   Reply With Quote
Old 10-09-2002, 09:30 PM   #19
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
"Whats new" GFZ
Large backlit display that graphs charge/discharge curves.
Rotary dial and less menues make setting up the T-35 easy
Discharges in a range of .5 to 35amps
higher charge rates from .1 to 20amps
higher amp motor run - 20amps
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-10-2002, 04:07 AM   #20
RC Nitro's Avatar
Thanks Troy.
Spaz: $30 more is what Jim told me yesterday when I called CE on another issue. They are not sure at this time on updating older T35 to the GFX. Will know more when full production starts. Jim also said that the new unit will charge TX batteries.
Old 10-10-2002, 04:38 AM   #21
thanks rc nitro looks like this thing will have plenty of features.
Old 10-10-2002, 04:47 AM   #22
RC Nitro's Avatar
Sure does. Showed the wife the info on the link Troy sent. She said OK to a new one Is it Feb yet???? he he
Old 10-10-2002, 05:49 AM   #23
dtm
dtm's Avatar
Send a message via ICQ to dtm
Your wife is very generous!!!!!
dtm is offline   Reply With Quote
Old 10-14-2002, 08:35 PM   #24
RCTech Member #2
TSR6's Avatar
Thanks Troy.
Yeah, I talked to Jim at the track on Sunday, and i was given the same information. $30.
I guess quite a few guys from this thread have talked to him..
Am i not suposed to charge TX packs with my Stealth? heh, I do it all the time, and have not had a problem yet.
-Troy
Troy
RCTech Member #2
Old 10-15-2002, 04:57 AM   #25
Default Turbo 30.
Now what is the difference between a turbo 35 and a turbo 30? Is it just the 5 amp difference between discharge that they have or is there more?
rcpilot is offline   Reply With Quote
Old 10-16-2002, 08:36 AM   #26
RC Nitro's Avatar
dtm: Yea I do,
Troy: That is what I was told when I called Tech support in June when I got the unit. Will have to try a Tx pack. I normally use my SuperNova to charge the TX and Pb batteries.
Old 10-16-2002, 08:39 AM   #27
RCTech Member #2
TSR6's Avatar
rcpilot - I know some T-30's did not have flex charging ( for nicad ). Also, somewhere along the lines ( not sure when ) they added Actual Resistance to the cycling info. Im not sure if that was with the T-35, or the Stealth.
rcnitro - I charge my packs with it all the time... news to me! My PitBull will only charge the packs a little... and i get a "low amps" error. But on the Stealth, i have no problems.
Maybe i should talk to Jim?
-Troy
Troy
RCTech Member #2
Old 10-16-2002, 08:41 AM   #28
RC Nitro's Avatar
-Troy
If you do let me know what he says.
John
Old 10-28-2002, 08:42 AM   #29
RCTech Member #2
TSR6's Avatar
RC Nitro - I knew i was doing something right. :P
Stealth will charge TX and RX packs just fine, like i thought.
The GFX will be able to discharge them though...
Troy
RCTech Member #2
Old 11-03-2002, 08:21 PM   #30
RCTech Member #2
TSR6's Avatar
some new pics of stuff that CE is testing out. The picture here is not the "final" version yet
Troy
RCTech Member #2
turbo 35 and turbo 35 gfx differences xrayflorida Radio and Electronics 1 06-04-2008 02:54 PM
Differences between 3port vs 5 port, Turbo vs Non turbo nikkor Onroad Nitro Engine Zone 2 09-28-2005 06:24 PM
Turbo 35gfx versus BL Stealth...any differences? jlou671 Electric On-Road 9 09-30-2004 11:52 PM
Differences between Turbo 30 and 35? Impreza Electric On-Road 28 09-26-2002 09:04 PM
Any significant differences between $$$ peak charger and regular peak charger? Dealer Xing Electric On-Road 18 08-30-2001 11:12 PM
