Old 09-28-2005, 07:34 PM   #1
Default Charging 3300 with Duratrax ICE
Hi guys could you please help me i have my 3300 matched team orion and would like to know what is the best setting to charge these to give me the outmost. By the way i also have Novak equalizer so i will make sure i discharge them first.
I will be running STOCK with a 21 turn.
One last thing i have 3000 also can i use the same settign as the 3300 ?
Thanks for helping
speed6 is offline   Reply With Quote
Old 09-28-2005, 08:20 PM   #2
Registered User
xrcbuggy's Avatar
Use the step charge example in ICE owners manual, that works great. I have tested w/my GP 3300. For the 1st charge, monitor the charging closely to make sure everthing is working correctly.
xrcbuggy is offline   Reply With Quote
Old 09-28-2005, 09:37 PM   #3
schmelme's Avatar
Dont use the step charge till you are familar with your packs and how many mah they usually take and temps when they peak.
Good start is 6amp charge .4-.5mv peak detect make sure you set it to 6cell 3300mah capacity. As long as you leave the peak lock out at around 5min these settings will work fine for your 3000's also.
schmelme is offline   Reply With Quote
Old 09-29-2005, 06:08 PM   #4
Default Step Charge
I saw this thread, and decided to try the step-charge. The charger promts for a sensor, and I wanted to know where to get one so I can try this.
onthegas is offline   Reply With Quote
Old 09-29-2005, 06:32 PM   #5
Try Tower they surely have it in stock.
Dear schmelme i trid charging as you said but the batt arent getting charged fully they are like giving me only 3n to 4 min
i set it to 6 amps but found out that sometimes it was resetting itself to 0.50 AMp why is that ?
Thanks Ramon
Old 09-29-2005, 06:52 PM   #6
schmelme's Avatar
You have to set up a charge profile and save it then it will keep the charge settings.
How many MAH is the battery when it peaks? Should be at least 3300 min.
Step Charging GP 3700 and GP 3300 rcnewb2004 Electric On-Road 3 07-20-2006 12:31 AM
3300 charging LancerEvoV Rookie Zone 8 07-24-2004 08:05 AM
charging 3300 battery? mrredrsx02 Electric On-Road 16 11-27-2003 09:27 AM
Charging Sanyo 3300 fai Electric On-Road 2 12-18-2002 07:24 AM
