Christmas 2014 ff03 build
1 Attachment(s)
Decided to post as I build. Any tips are welcome. Box stock ff03.. Here we go
1) ball diff
2 Attachment(s)
Pretty straight forward except tricky turn upside down part I seen people mention.
2) Idler gear
2 Attachment(s)
Just like the picture
4) gear case
3 Attachment(s)
Decided to try and upgrade any Phillips head screws with socket heads, button heads or tappers if I can
4) Motor plate
3 Attachment(s)
Socket heads soooo much better. I dont have 48mm screws all I have on hand are 50mm's so I may have to shim or grind the two motor plate bolts.
5) Spur gear Attachment
2 Attachment(s)
I think I going to find better differential drives and the spur gear hub is cheesey. I trimmed the bolts I had to 48mm for clearance.
6) damper stay
2 Attachment(s)
Lots of pieces just for a damper mount.
nice build. I have always liked the ff series cars. what body is that? i don't recognize it.
7) Steering Linkage
2 Attachment(s)
Wonder if this steering rack will hold up? Put some ag grease on the bushings. Feels nice and tight.
Originally Posted by ThePanda
(Post 13740580)
8) front suspension mount
2 Attachment(s)
I used the 1XD just like the manual shows. I'll be running this on asphalt tracks and parking lots we can find that are smooth.
9) steering linkage mounting
2 Attachment(s)
Really wish I had more tapper head socket screws for the flush mount. I'll have to get more screws after this build.
10) front arms
2 Attachment(s)
Think I got them in the correct orientation. I didnt think it was necessary to widen the droop screw holes with a 3mm drill. At least I think that's what those grub screws are for.
11) Mounting a-arms
1 Attachment(s)
I don't think these pivots will last.
12) gearcase attachment
2 Attachment(s)
Starting to look like something. Really really wish I had tapper head socket screws and an electric screwdriver.
