Old 09-26-2005, 03:50 PM   #1
Send a message via MSN to milen
Default motor suppression
Hi guys, I got a problem, my engine got so hot, the solderings holding the capacitor for suppression failed and the capacitor got lost.
Whit what kind of capacitor should I replacce it?
The engine is a team associated stock 19 turn.
milen is offline   Reply With Quote
Old 09-27-2005, 05:05 AM   #2
geeunit1014's Avatar
normally u just use the ones that come (pre attached)with the motor. if its getting so hot the solder melted, its time to gear down!!! use a bigger spur gear r a smaller pinion gear, and re-solder the cap. back on
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-27-2005, 07:13 AM   #3
wierd, since the car is all stock, so the factory sendswrong gears?
Old 09-27-2005, 01:00 PM   #4
how big is the track you're running on?
Mike Gee
Old 09-27-2005, 02:41 PM   #5
Tek Nickal's Avatar
I wouldn't think the manufacturer would send wrong gears, but generally it wouldn't be the right gearing for the motor (engine) your using.
Tek Nickal is offline   Reply With Quote
Old 09-29-2005, 08:58 AM   #6
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
For starters, that motor is pure junk as goes with every RTR R/C motor. All RTR motors are like this.
Sean
Team Duratrax is offline   Reply With Quote
Old 09-29-2005, 09:47 PM   #7
ok so i should change my engine?
I,m not running on a track, i use it for drifting in my driveway.
Anybody who can explain all about the specs of en electric engine, i mean what nb of turns, spurs..., mean and how they change performance of the engine?
Old 09-29-2005, 09:57 PM   #8
nagatahawk's Avatar
Default hot motor
milen,
That motor should be good for drifting, but you have to change the rubber tires to abs. if you want set ups for drifting. go to driftrcentral.com I know the people that run the site and all are the finest drift pilots on the west coast. good luck.
keep it sidways.
nagatahawk is offline   Reply With Quote
Old 09-29-2005, 10:02 PM   #9
tnx, I know about the tyres, for now i m using taped tyres having just baught the car and having no money to buy another set of rims, but l8r on...
Old 09-30-2005, 11:03 PM   #10
This will help: http://www.actionrc.com.au/Section_9.htm
Sean
Old 10-01-2005, 06:53 AM   #11
Joel Lagace's Avatar
one of the mags reported the motor to be junk and to run to hot. my lhs got a few customers report that there motor ran too hot as well. its a low grade motor get a stock motor like p2k2 and u will be much much faster!! 27t stock motor will blow that motor away
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
Motor Suppression badpapa Singapore R/C Racers 1 01-20-2008 06:24 AM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Capacitor Sizes for Motor Suppression mikeleigh Electric On-Road 0 05-20-2004 08:11 AM
EMI Suppression Cores Suradaj Electric On-Road 22 01-10-2004 09:33 PM
