Old 09-26-2005, 02:09 PM   #16
AdrianM's Avatar
RW gears are machined out of Acetyl Engineering Plastic (AEP). It is harder than Delrin and unlike Delrin and Nylon...AEP is completely temperature and humidity stable. This means that the day they wear out they are just as flat and round as the day they rolled out of the milling machine.
All RW gears are gauranteed to be concentric to 1/1000" or they will not leave the factory.
They fit all cars including Xray spur adapters.
Adrian Martinez
Old 09-26-2005, 06:39 PM   #17
POOKYT's Avatar
Originally Posted by rcnewb2004
have q about thoseprs pinions... since they are aluminum are they easy to strip? (I actually stripped the threads on the pinion gear... where u screw the grub screw in) that's why now i am hesitant to buy more aluminum pinions...
seems that if i don't tighten the grub screw enough, the pinion won't stay attached and if i tighten it too much, then it strips... maybe i did something wrong?
Although the pinions are aluminum they are hard coated and are very strong. I have been using aluminum pinions( 64 pitch) outdoors for over 3 yrs now and have had no problems at all. These PRS gears and the Robinson ones I use are the newer versions which have a 5-40 set screw and last 100 times longer than my old ones with the 4-40 set screw. Good Luck
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-13-2005, 01:07 AM   #18
Send a message via ICQ to rcnewb2004
Does anyone know if the RW-Racing spur gears will fit the tamiya ta04 spur gear hub??
rcnewb2004 is offline   Reply With Quote
Old 10-13-2005, 08:16 AM   #19
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I have to disagree Adrian,
I bought two of the RW gears for my RDX...they do not fit.
Although quality is there, they are just like .5mm off on the screw holes.
The PCS from EA fit everything I have tried, the RDX, the Yok BD the Yok LCG...
The new one from EA the 104 fitted for pan car fits the RDX the best.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-13-2005, 08:24 AM   #20
AdrianM's Avatar
-Shookie <><
The locations of the hole circles on the RW gears are industry standard (Kimbrough) dimensions. I have heard (from Corally drivers) that the RDX bolt circle dimnesion is what is a bit off.
Adrian Martinez
Old 10-13-2005, 08:26 AM   #21
Most likely true...LOL
Still though...that new camber guage is the shizzle....I think I got like four guys lookign to get them...LOL...sure does beat taking out the whole setup system...and if you lay it flat you can even get a very close toe in or out....
Just wish it were black or blue...Purple just messes me up...Might have to do a little oven off work...LOL
-SHookie <><
Old 10-13-2005, 08:32 AM   #22
Shane Reinink's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Shane Reinink
I have an RW 108t spur on my RDX and it fit perfectly.
Shane Reinink is offline   Reply With Quote
Old 10-13-2005, 08:36 AM   #23
Well maybe its just the 104 that didn't fit.
-Shookie <><
Old 10-13-2005, 08:48 AM   #24
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The Pro-Lite Oval gears are the ones that fit the RDX perfectly with no modifications at all. They are machined and perfectly round. They will not break teeth off in hard wrecks either. I know of several factory guys that run the PRS gears in 64 pitch even on asphalt using full brakes!
All other touring cars take the standard PRS TC gear. They are made the same way as they others but just have a differnt hole pattern.
You wont be dissapointed in these gears or thier prices.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-13-2005, 08:51 AM   #25
WORD.....
EA
Old 10-13-2005, 09:55 AM   #26
Where would be a good starting point for 64 pitch pinion and spur on a TC3 and XRAY EVO2. I race both stock and 19 turn. The tire diameter is 59mm. Thanks for the help.
Kevin
KevinL is offline   Reply With Quote
Old 10-13-2005, 10:11 AM   #27
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Don't know about the RW-Racing Spur gears but the PRS gears fit perfectly on the TA04
minicooper is offline   Reply With Quote
Old 10-13-2005, 02:48 PM   #28
I don't mean to be rude... I love the way this RDX conversation is going... but the poor guy (me) here needs to know does tamiya follow the industry standard... (i hate them for making everything slightly different so u can't interchange your parts with other companies sometimes).
Thanks once again.
Old 10-13-2005, 05:54 PM   #29
stonedgti's Avatar
Trader Rating: 15 (100%+)
JWerks RC is coming out with one that is pretty similar to the RW, except it's a tiny bit thicker, thus a bit more durable. It's also made from a new Delrin like material called Moxinyethen. It's suppose to be stronger and lighter than your regular Delrin because of the tighter molecule stucture. It's suppose to be out soon...so we'll see.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 10-14-2005, 07:39 AM   #30
AdrianM's Avatar
Thanks once again.
Yes, Tamiya does follow the industry standard. One of my race buddies has a 415MS an he uses RW gears.
Adrian Martinez
"WTB" RW 108 Spur Gear BSchorr R/C Items: Wanted to Buy 0 12-17-2007 04:49 AM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
