USGT spec tires
Old 04-20-2016, 09:00 PM
  #46
LasagnaCat's Avatar
Trader Rating: 160 (100%+)
Originally Posted by robk View Post
I'm not sure what anyone wants.
Five years/40,000 miles?
All jokes aside, the current tires have been great.
LasagnaCat is offline
Old 04-25-2016, 12:10 PM
  #47
Iketruman's Avatar
Trader Rating: 14 (100%+)
I have been searching all day about this, so what is USGT? What chassis, what motor, most of all what tires? RC Gravity is out or has stopped making them. What body? Please do not send link to roar rules, it really does not state the answers.
Iketruman is offline
Old 04-25-2016, 12:20 PM
  #48
Trader Rating: 38 (100%+)
http://www.teamgravityrc.com/store1/...egory=15430106
They look to be in stock to me. As for the rules, open this link and scroll down:
http://www.usvintagetransam.com/rules/
linkless is offline
Old 04-25-2016, 12:34 PM
  #49
scirocco14's Avatar
I typed "USGT Rules" into Bing. 1st result at the top. 2nd and 3rd results will get you there too.
That should help you!
Mark
scirocco14 is offline
Old 04-25-2016, 12:50 PM
  #50
fyrstormer's Avatar
Originally Posted by Paco1001 View Post
Well maybe they could start putting in a quality insert that will help out the tire for a span more than 2 months. I still don't get why there is a spec tire for any class. Maybe a tc slick and a scale looking rim would be the solution. now you have a tire that will last a season or more and eventually everyone will gravitate to a tire that works for them. That would be way cheaper tire overall if i'm not replacing a set once every 2-3 months.
Spec tires exist to ensure everyone on the track has the same amount of traction. It makes the race fairer -- you have to actually be a better driver in order to win, instead of buying victory through better parts. You can tune how your car uses that traction by adjusting the alignment on the wheels and the weight balance of the chassis, the same way you can tune how your car uses the power from a spec motor by adjusting the gear ratio. Some classes even go so far as to specify which chassis you can run and which upgrades you're allowed to put on it.
$15 for a set of four tires is actually quite inexpensive compared to pretty much any other option available. And if you really think a set of tires can last for an entire season of racing, you must not race very often.
If you're destroying the outer edges of your tires, it sounds like you need to dial-in some more negative (inward) camber in the rear, and more positive (rearward) caster in the front.
fyrstormer is offline
Old 04-25-2016, 12:59 PM
  #51
Iketruman's Avatar
So the 4wd run with the Fwd? Type in RIE 24025 and Gravity RC comes up not available. Body explanation is crap, what bodies are popular?
Old 04-25-2016, 01:00 PM
  #52
theproffesor's Avatar
Trader Rating: 63 (100%+)
I've got quite few race days and practice sessions on my spec usgt tires. Lasted alot longer than my last set. Rims and inserts go well before the tire. Yes a better insert would be nice, but it is what it is and we all have the same problem to deal with. And the price would go up.
I like the idea of rotating the older reads to the front and newish rears.
The front wear a lot faster. Due to the way we drive these cars. I now running a diff and maybe that will help some. Not hitting everything on the track but the racing line will probably help too.
theproffesor is offline
Old 04-25-2016, 01:03 PM
  #53
You want the ones posted in the link above and they are available in lots of places. You can get them as just the tires and inserts or premounted.
Old 04-25-2016, 02:29 PM
  #54
ASM
ASM's Avatar
Trader Rating: 28 (100%+)
Not so sure the rules are that difficult to understand. If you do some homework, the popular choices are fairly easy to find. If you read the numerous race threads posted on this site, those will also often times tell you what was used.
The PF Caddy and Camaros, The McAllister MX Stang and Daytona Prototypes, along with some various Tamiya and HPI bodies are all popular choices. All are good and there are many more to choose from. That's a lot of the appeal of the class. Track surface, size and layout may also be a factor for you as well.
This thread and the USGT Paint thread both have information pertaining to your question.
ASM is offline
Old 04-25-2016, 02:33 PM
  #55
Iketruman's Avatar
Got it, thanks.
Old 04-25-2016, 06:28 PM
  #56
robk's Avatar
Trader Rating: 22 (100%+)
This why I love all of you
robk is offline
Old 04-25-2016, 06:43 PM
  #57
fat500's Avatar
Trader Rating: 35 (100%+)
lmao
fat500 is offline
Old 04-25-2016, 07:05 PM
  #58
mikel33's Avatar
Trader Rating: 2 (75%+)
reading is a highly over rated skill.
mikel33 is offline
Old 05-10-2016, 01:53 PM
  #59
Trader Rating: 31 (100%+)
HI!
I have no experience on asphalt track with USGT/ Ride spec tires, is there any advantage or recommendation on using tires warmer ? Thanks!
pat5b is offline
Old 05-10-2016, 03:37 PM
  #60
Originally Posted by pat5b View Post
HI!
Tire warmers will help on cooler days. I was at a parking lot race, this last weekend and a lot of guys were using Liquid Wrench (lubricanting oil) for tire treatment. It seemed to work well.
mooby64 is offline
