Old 10-06-2002, 11:20 AM   #1
madweazl's Avatar
Default TC3 gearing help
Need some help selecting gears for the TC3. Team kit with with Orion 3000s, 24* Core stock (orion), and a 14X2 Core Orion. What do you recommend for gearing and is there a company that sells a set of pinions that I could pick up?
madweazl is offline   Reply With Quote
Old 10-06-2002, 12:12 PM   #2
wheelmanST's Avatar
Send a message via AIM to wheelmanST
depends on how big the track is but with a GM3 im running a 28 to 29 tooth pinion and with a p2k2 im running the 29. thats a good setting for a track that doesnt require tons of torque. for the mod i dont know cus i only run stock. hope that helps!
wheelmanST is offline   Reply With Quote
Old 10-06-2002, 12:13 PM   #3
wheelmanST's Avatar
o yea...im running a ft tc3
Old 10-06-2002, 06:18 PM   #4
im not sure about the core stock, but with a p2k2 i run 96/36 64p on a small but flowing track layout, this has good speed through the infield as well as pretty good top end, i would guess the core may be close to this gearing on a similair track lay out.
Jarrod Langlois is offline   Reply With Quote
Old 10-07-2002, 07:00 AM   #5
madweazl's Avatar
I found a set made by Bolink that has from 12-30t pinions (as I recall), will those work ok in the TC3. I dont know how they are sized or how much room is available for them.
Thanks for the recommendations.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
