Old 10-10-2001, 09:26 PM   #16
TFR
TFR's Avatar
Wa, There is different Capacitor that we should use?
TFR is offline   Reply With Quote
Old 10-10-2001, 11:49 PM   #17
Send a message via ICQ to JesseT
It would further improve the efficiency, but be careful. The capacitance is not the key figure, but the internal impedance at Mhz range, so don't just put any capacitor to your Cyclone. You definately need a high frequency type.
JesseT is offline   Reply With Quote
Old 10-11-2001, 09:17 PM   #18
Trader Rating: 69 (100%+)
thanks JesseT. how do i now if its a high frequency type? i plan to use a Rubicon brand capacitor with the ff. specs: 6800mf, 10v, 105 degrees C, and a label that says MH 09
TFR: novak specifies the particular capacitor that comes with the esc as the one you should use. but i just want to experiment with another. other guys in our track are using different capacitors.
marvi is offline   Reply With Quote
Old 10-11-2001, 09:28 PM   #19
TFR
TFR's Avatar
OH...okok
Old 10-11-2001, 11:19 PM   #20
The Rubycon MH is a general purpose (low cost, not good at anything) capacitor, that has a low impedance only to some hundreds Hz. If you use a better capacitor like XL, ZA, YXG,...etc. you will get over four times more effect with same uF and V values. The speedo needs a capacitor that goes up to Mh and more.
Old 10-12-2001, 08:27 AM   #21
thanks im just gonna look for those brands you mentioned. for the meantime, i think ill just stick to the stock capacitor.
Old 10-16-2001, 08:17 PM   #22
TFR
TFR's Avatar
Got a quick question...
If the Power Capacitor is put on the Cyclone...i heard ppl say that the Cap will "eat" up the batteries life?
is that true?
Old 10-17-2001, 12:14 AM   #23
I heard this for the first time now and.... hmmm... I think it's rubbish. Is there an explanation of why this would happen?
Old 10-17-2001, 06:00 AM   #24
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Well, a capacitor does store small amounts of energy, But i don't think its large enough to even affect runtime by a second... prolly mili-secs if it does. I'm not sure though... I don't think it would..
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-17-2001, 06:14 AM   #25
Cole Trickle's Avatar
A capacitor can't eat up batteries. The battery capacity is far superio compared to a capasitor.
A 3000 NiMh got around 0,3 Farad. The capacitors used on ESC's is around 4700 micro Farad. So there's asomething like factor 1000 in difference. Besides, when the capasitor is fully charged, it don't draw any more current. And when the car accelerate, the capacitor deliver what's stored to the motor.
A kind of conclusion: The story about ESC capacitors eat up batteries, is rubbish.
Cole Trickle is offline   Reply With Quote
Old 10-17-2001, 06:41 AM   #26
What makes you say the Nimh has 0,3F capacitance??? How do you measure that? And your statement that acceleration eats up the charge from the cap is dead wrong. Period. That is not how the capacitor works. It is not an energy reserve for accelerations!
Old 10-17-2001, 02:42 PM   #27
TFR
TFR's Avatar
Sorry, my bad...
Old 10-17-2001, 11:35 PM   #28
Just to compare energies:
If a battery has 3000mAh at 7.2V that means it can supply 3A for 1 hour (3600s) at 7.2V. This leads it to having an energy of 77.760kJ.
If a capacitance has 2200uF and it's loaded to 7.2 V it has an energy of E=(1/2)*C*U^2=57.024mJ.
So the energy ratio is 1363636. Over a million...
Old 10-18-2001, 03:48 AM   #29
Send a message via AIM to ZER01
Listen to Charlie, I dont think he would be where he is if he didn't know what he was talkin about. Whats-up Charlie?
ZER01 is offline   Reply With Quote
Old 10-18-2001, 04:02 AM   #30
Charlie, are you really really sure about your statement on the schottky earlier? On free spin the voltage generated is of the same polarity than the one fed from the speedo but the shottky is reversed. On the other hand, when feeding current from the speedo to the motor (on pulse mode of course), the shutting-down period would generate a negative pulse from the motor and this would effectively be absorbed by the shottky. Does this make any sence to you?
BR/ JesseT.
Novak cyclone original model..... SCUBA STEVE R/C Items: For Sale/Trade 4 02-05-2006 12:39 PM
KO radio, Novak GT7, Novak Cyclone, Servos, TC3 RichChang R/C Items: For Sale/Trade 14 10-03-2005 08:54 PM
F/S - Novak Dually & Novak Cyclone ESCs rctoyguy R/C Items: For Sale/Trade 9 04-13-2005 09:45 PM
FS:Losi MFE1,Novak Cyclone and a 27mhz Novak XXL TexRacer R/C Items: For Sale/Trade 0 03-08-2005 03:16 PM
FOR SALE: XXX BK2, Novak GT7, Novak cyclone 2nd edition gporta77 R/C Items: For Sale/Trade 2 07-18-2004 06:18 PM
