Old 10-07-2001, 12:23 AM   #1
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default diffs baby!
ok, this is elementary, but i'm curious. how tight do you run your diffs? i have a schumacher with tc diff balls and though my diffs are smooth, they don't spin too easily. there is considerable resistance. my friend's tc3 diffs don't slip, yet when i spin the wheels with my hand they keep going for a few turns. my schuie does not. what about you? if you manually spun one of your tires moderately, do they keep rotating after you let off? should they? let me know.
seaball is offline   Reply With Quote
Old 10-07-2001, 01:27 AM   #2
zxt
zxt's Avatar
Default Well...
I set mine just when the screw stop...so you can not consider that as tight but its not loose also...just in the middle. If I do any tighter than that then I can feel the resistance....
well you can try it and post here the results...
zxt is offline   Reply With Quote
Old 10-07-2001, 01:37 AM   #3
Alvin's Avatar
Quite a bit of discussion in this thread:
http://www.rctech.net/forum/showthre...=&threadid=502
Alvin is offline   Reply With Quote
Old 10-07-2001, 08:32 PM   #4
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I usually set my diffs (touring) just tight enough that they don't slip, that way they tend to unload in the corner less.
Core Creations is offline   Reply With Quote
Old 10-27-2009, 01:15 PM   #5
~McSmooth~'s Avatar
Thumbs up
Sometimes, your diffs will take a run or two on the track to free up (like you describe) after a fresh rebuild.
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 10-27-2009, 01:27 PM   #6
seaball's Avatar
is there a handling difference between a loose and a tight diff, assuming neither slips under power (or off)?
*** The Gate II - Home of Mike Wise ***
Old 10-27-2009, 03:02 PM   #7
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
My MI4 diff is just tight enough not to slip and it will free spin a few turns. And its smooth as butta
I think one of the biggest things is to sand the D rings completely flat. That helps a ton
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-27-2009, 03:16 PM   #8
BlackedOutRevo...you sir are missing the point just answer the question...see previuos post to yours...
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 10-27-2009, 03:44 PM   #9
amnesia's Avatar
Does anyone know where you get the diff ring holder tool from that Jilles uses in this video http://www.youtube.com/watch?v=YOMu6Fu3orI
Great video series if you've never seen it BTW
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
www.titaniumracing.com
amnesia is offline   Reply With Quote
Old 10-27-2009, 04:18 PM   #10
No in his first post he asked how much resistance everyones diff had. And he has the same car I do.....
Im not positive what a tight diff drives like over a looser diff so I didnt answer that. All I know is I have always run my diff as loose as possible with out slipping and its worked just fine Never messed with a tight diff in the rear
Old 10-27-2009, 05:12 PM   #11
JayL's Avatar
in the rear
Tight diff makes the car push
loose diff adds steering
assuming it is not slipping
JayL is offline   Reply With Quote
Old 10-27-2009, 07:14 PM   #12
Originally Posted by JayL View Post
in the rear
1
Bingo...lol
www.OHRCR.com
Old 10-27-2009, 08:00 PM   #13
Bingo...lol
So if you knew what it did, instead of telling me to answer... Why didnt you just answer it your self?
amnesia- I just use a spare female diff outdrive to sand the rings Does the same thing lol. But I know rc market has them.
Old 10-27-2009, 08:01 PM   #14
Trader Rating: 38 (100%+)
McSmooth strikes again! (with assist from seaball). An 8 year old thread.
or8ital is offline   Reply With Quote
Old 10-27-2009, 08:45 PM   #15
rcterp's Avatar
Trader Rating: 35 (100%+)
Well played gentlemen.... well played.
rcterp is offline   Reply With Quote
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 11:48 AM
My new baby! Stewart Fan Electric Off-Road 14 03-26-2006 06:37 PM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
Take it off baby!!! Samma3l Australian Racing 9 03-20-2003 06:54 PM
One-Way Diffs vs. Diffs in Kits eBoi31 Electric On-Road 14 04-13-2002 11:02 AM
