Old 10-03-2005, 02:27 PM   #31
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Originally Posted by yellow15
anyone?
-IRS160 Associated Style Pod Plates (pr.) - Blue - lowered 0.090 than stock pod plates
These are the ones that fit the standard 12L3/L4 hole pattern in the top and bottom pod plate, as well as CRC, Speedmerchant, etc.
-URS1161 1/12th Pod Upgrade - For Associated 12L4 - Blue pod plates
This is an entirely new pod that uses 4 bolts to hold it to the upper pod plate. Requires new upper and lower pod plates to work. Supposed to be stiffer and more precise than the other style.
-IRS163 Extended Pod Plates for Associated Style Pan Cars
These have the bearing holders moved back 1/8" or so to extend the wheelbase and allow more room for bigger gears. These are generally for oval and not used on roadcourse cars.
-James
JamesArluck is offline   Reply With Quote
Old 10-03-2005, 02:50 PM   #32
-James
so sounds like URS1161 is the best option? But looking at the design, would it be very difficult to remove/install the motor?
yellow15 is offline   Reply With Quote
Old 10-03-2005, 03:00 PM   #33
What do you think about this set:
Corally SP12M Ahoniemi SPEC
ESC GTX
Servo Airtronics 94145
Batteries IB3800
Battery pack GP 1/3AAA 160mah 5cell
Spektrum+M8
Motor Spashett 8x2
Tires front silverstar, rear pink
servosaver Kimbrough
Speed12 Protoform
Acer balls in the diff, BTW what is size of those balls?
did i forgot anything?
Tral is offline   Reply With Quote
Nsram ISTC, KO-PROPO 12th scale servo, JR and Hitec 10th scale servos crabboy Australia For Sale/Trade 2 07-14-2008 03:23 AM
Pro Parts 12th scales, lots of parts! 12th scale foams! megasaxon R/C Items: For Sale/Trade 4 03-17-2008 03:46 AM
BMI 1/12th scale, Hara 1/12th, bodies Mdoc R/C Items: For Sale/Trade 0 07-07-2007 10:26 AM
HUGE LOT OF 10TH SCALE & 12TH SCALE PAN CAR PARTS RED-LINE M03 R/C Items: For Sale/Trade 11 10-12-2006 04:57 PM
1/12th scale to end all 1/12th scales... dr_hfuhuhurr R/C Items: For Sale/Trade 22 04-21-2005 06:07 PM
