Old 09-22-2005, 07:05 AM   #16
theisgroup's Avatar
Originally Posted by RandomFellow
You do if you want to get the most out of your servo (4.8V vs. 6.0V).
not in stock. the added weight even of a 5 cell 1/3aa is just too much to give up in stock. I run a ko949 with no receiver pack and have never had a problem. My PT give out before the servo slows down enough for me to care.
if you run stock, pull your receiver pack. you will probably pick up .1 to .2 per lap and in 8 min, that is alot
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-02-2005, 05:14 AM   #17
Originally Posted by JamesArluck
-Lowered pod plates (allow you to use smaller tires while still maintaining correct ride height, CRC and IRS make good ones that are reasonably priced)
-Lowered front arms (allow you to use smaller front tires while still maintaining correct ride height, IRS sells these)
-IRS rear ride height adjusters (allow you to adjust the rear ride height in .5mm incriments, much finer than the stock AE ones)
THere are so many different ones there.. what should i get?
yellow15 is offline   Reply With Quote
Old 10-02-2005, 02:53 PM   #18
Or maybe,
can someone tell me the pros and cons of the following:
IRS160 Associated Style Pod Plates (pr.) - Blue - lowered 0.090 than stock pod plates
URS1161 1/12th Pod Upgrade - For Associated 12L4 - Blue pod plates
(Seems to be stronger? but maybe heavier and more difficult to remove the motor?)
IRS163 Extended Pod Plates for Associated Style Pan Cars
Old 10-02-2005, 09:24 PM   #19
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
I am also looking into getting a 12 scale car ( got $200 to spend for one )and after reading most of the different forums in here I've come to this conclusion...
1. rc12l4 is the best starting kit, plenty of parts and hop-ups
2. Stay away from the turnbuckle type brace and go with rigid upper pod plate and fiberglass T-bar. Trinity Black widow and the Yokomo do not have the rigid upper plate so I'll pass on them ).
3. Stay away from the hops-up until you have some drivind and racing experience, replacing parts is cheaper this way.
4. Read the &%&*(*^(#@#% manual first before building the car.
5. Get a decent servo...... And servo saver!
6. Use old 6 cell packs that had one of the batteries go meltdown.. Cost saving tip...
7. Don't tell wife you are loking to get a new car....
8. Have package delivered to your workplace of friends house.
Did I miss anything?
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 10-03-2005, 01:13 AM   #20
Merciless's Avatar
Send a message via ICQ to Merciless
Lol no i think you covered it ...... the last 2 seem very familiar
Merciless is offline   Reply With Quote
Old 10-03-2005, 05:01 AM   #21
Mart42's Avatar
Best kit to get for the $$$, CRC T-Fource. You get the lowered pod plate and a good set of foam, right in the box.
MARTIN LECUYER
Team Associated - Reedy - SMC - Team Scream - BSR - SlyGraphiX - Carpy's
[email protected]
Mart42 is offline   Reply With Quote
Old 10-03-2005, 07:33 AM   #22
CRC, don't know much about that one... Is there a quick and fast website for info? Parts?
Never mind... I looked at a pic and it has the turnbuckles and not the rigid plate...
RC Tech member #11
Old 10-03-2005, 08:15 AM   #23
Merciless's Avatar
The "T" Force has a T plate i suspect you looked the the carpet knife which is a link car
T-Force
Old 10-03-2005, 08:21 AM   #24
Soviet's Avatar
Originally Posted by factory racer
Why would i need this BMI conversion????
thanks
Mike
Answer: You don't
The 12L4 is perfectly fine in stock trim. If you want to add ANYTHING usefull, simply get the CRC lowered rear plates and IRS lowered front arms with shims.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 10-03-2005, 10:33 AM   #25
[QUOTE=Merciless]The "T" Force has a T plate i suspect you looked the the carpet knife which is a link car
T-Force
I do believe you are correct sir...
RC Tech member #11
Old 10-03-2005, 10:44 AM   #26
mtveten's Avatar
Trader Rating: 27 (100%+)
Could someone please explain the link-type VS t-bar suspension to me? I am not looking for a debate as to which one is better but would like to know what some of the advantages or design focus of each is?
Mark
mtveten is offline   Reply With Quote
Old 10-03-2005, 10:56 AM   #27
OK looking at the CRC website they have 6 different 12 scale kits listed.
I assume the 6 pack means 6 cells.
That leaves the carpet knife and t-force..... I assume they are both are ROAR type class kits.....
Before I order it what is the biggest difference between the Team RED and standard t-force? And the carpet knife and team carpet knife???? Besides the $$$
THX
RC Tech member #11
Old 10-03-2005, 11:25 AM   #28
Merciless's Avatar
THX
I believe it's just down to lots of shineyness on the Team red's
Personlly i'd go with the t-force after having a 3.2r and never being able to get it to go "right"
I'm running a bmi with side dampers right now, which would be very similar to a t-force without the lower springs at the rear being used
I really like this set-up and it's going well !
Old 10-03-2005, 01:05 PM   #29
Regional Moderator
Mark Mixon's Avatar
Default 12th scale necessities
Not sure what environment you'll be running in, but in FL we usually need a table, chair, an EZ-up, some sunscreen, and a fan. If your running indoors, this equipment won't be necessary
FSEARA
"They may be toy cars, but I spend REAL money to race them!"- Racer X
"It's only a big deal if you make it one."
Mark Mixon is offline   Reply With Quote
Old 10-03-2005, 02:22 PM   #30
Originally Posted by yellow15
Or maybe,
anyone?
Nsram ISTC, KO-PROPO 12th scale servo, JR and Hitec 10th scale servos crabboy Australia For Sale/Trade 2 07-14-2008 03:23 AM
Pro Parts 12th scales, lots of parts! 12th scale foams! megasaxon R/C Items: For Sale/Trade 4 03-17-2008 03:46 AM
BMI 1/12th scale, Hara 1/12th, bodies Mdoc R/C Items: For Sale/Trade 0 07-07-2007 10:26 AM
HUGE LOT OF 10TH SCALE & 12TH SCALE PAN CAR PARTS RED-LINE M03 R/C Items: For Sale/Trade 11 10-12-2006 04:57 PM
1/12th scale to end all 1/12th scales... dr_hfuhuhurr R/C Items: For Sale/Trade 22 04-21-2005 06:07 PM
