WHICH BEARINGS?
WHICH BEARINGS?
hi
was wondering what bearings you think is best? metal or or teflon or rubber shielded... for off road i tried metal but where no good... too much dirt got in and not cleanable...
was wondering for on road is metal shielded is ok, would dirt be an issue?
thanks
thanks
Super Moderator
Originally Posted by qwerty
hi
thanks
thanks
http://www.acerracing.com/bearings.html
Originally Posted by Marcos.J
yes i know about them, but are they noticable?
Man don't get the Acer bearings.
The seals fall out. I would spend the little extra money and get the yellow sealed ceramic bearings for your drivetrain. I have the green sealed ones in my wheel hubs and they are lasting much much longer than any other standard bearing I have used. I'm sure the ceramics are the bomb.
Metal shields on asphalt work fine.
Super Moderator
Lightweight ceramic balls dramatically decrease the centrifugal force placed by the balls on the rings. This, in addition to a 50% higher modulus of elasticity than conventional bearings, and Grade 5 smoothness of the balls (contrary to popular belief the lower the Grade number a ball is, the rounder and smoother it is), produce a lower coefficient of friction at the ball-raceway interface, leading to over 33% less friction in the bearing as compared to conventional bearings, and far less wear, lasting an average of ten times longer than conventional bearings. Sealed with our exclusive no contact seals for the lowest friction and best dirt resistance. These are the best and most high tech seals available.
I like using the round ones.
