Old 09-21-2005, 12:45 PM   #16
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default try this
Check this product out.
It really works!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.aerocarlubricants.com/RC/index.htm
Later,
E
RED-LINE M03 is offline   Reply With Quote
Old 09-21-2005, 01:09 PM   #17
only once did i ever use com drops and never again.the gunk,the dirt and everything,plus a loss of performance!!!
wore the brushes down quicker and the comm was very dirty after the run.
i think a lot of people do not recommend using com drops.
if you do,little is better.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 09-21-2005, 01:15 PM   #18
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
for your motor sparay you should use magnum force and all the people at my local track says it makes the best traction they have ever tried
xrayaustin is offline   Reply With Quote
Old 09-21-2005, 01:16 PM   #19
xrayaustin's Avatar
sry!!! not magnum force, the stuff is called pb blaster
Old 09-21-2005, 01:29 PM   #20
RCMits's Avatar
Trader Rating: 25 (100%+)
PB Blaster?!? that stuff eats through plastic and other stuff.. its pretty corrosive. ever see PB Blast on styrafoam?
Stick with your Hobbyshop stuff... pay a bit more, and take the guesswork out of wondering what works or not.
RCMits is offline   Reply With Quote
where can I get some tribo tech comm drop straightaway Electric On-Road 11 04-20-2007 10:42 PM
Can brake cleaner be used as motor spray? revzalot Electric On-Road 44 01-20-2006 06:00 PM
Motor run-in alternatives milen Rookie Zone 13 12-11-2005 11:20 PM
Spray Paint Alternatives??? AndrewJCH Singapore R/C Racers 1 04-22-2004 10:02 PM
Motor Spray-What's in it CGR Electric On-Road 33 09-28-2003 05:34 PM
