Old 09-17-2005, 10:55 PM   #1
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Cooling fans
What fans are you guys using, where are you getting them, and how are you powering them up? (pics of setups are cool especially on Mi2s.)
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 09-18-2005, 12:39 AM   #2
polesitter61's Avatar
I use the Associated dual fans on my FK05, they plug directly into the reciever for power.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 09-18-2005, 12:44 AM   #3
loopedeloop's Avatar
I use these from ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...Pr4_PcY_BIN_IT
loopedeloop is offline   Reply With Quote
Old 09-18-2005, 03:40 AM   #4
mutley001's Avatar
See the thread entitled Cool-Can-Fan website now up an running or www.coolcanfan.com . Cost a lot but well worth the money for an exact and strong c/f mounting bracket and either 1 or 2 fans for many different cars including the Mi2
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 09-18-2005, 06:42 AM   #5
RKeasler's Avatar
What do you do to power a personal transponder and fan at once?
ClemsonTigers
USVTA # 224
ERC
Old 09-18-2005, 06:47 AM   #6
raving-monkey's Avatar
Send a message via MSN to raving-monkey
you can ujse a Y-lead..you can plug both into the reciever then....
not sure about ROAR etc but the BRCA state that you cannot have anything else plugged into your reciever other than esc, servo anda PT so it must be soldered directly to the battery wires.
raving-monkey is offline   Reply With Quote
Old 09-18-2005, 08:33 AM   #7
kerry's Avatar
can't you plug the fan into the 3rd channel spot on your receiver? 1&2 esc, servo, 3 fan 4or batt for personal transponder.
kerry is offline   Reply With Quote
Old 09-18-2005, 09:26 AM   #8
You can wire in a switch and soilder it directly to your speed control. That way you can leave the fan on after a race to cool down the motor. Once you are done marshalling your motor is cool to the touch.
pops is offline   Reply With Quote
Old 09-18-2005, 03:13 PM   #9
Yes, you can plug the fan or the transponder into either the 3rd channel or the BEC circuit on your reciever. I have a spektrum reciever and it works just fine Channel #1 and 2 steering and throttle, #3 are the fans, and #4 is the transponder.
www.slickzero.com
engine cooling fans Pazzy109 Nitro On-Road 24 02-24-2007 08:30 PM
ARE COOLING FANS WORTH IT? gonzo416 Electric On-Road 41 02-03-2007 06:12 PM
Cooling fans BillyCaldwell Electric On-Road 11 07-01-2005 07:54 AM
Cooling Fans under batteries Kennedy Australian Racing 2 08-28-2003 03:29 AM
Motor cooling fans? jwwu Electric On-Road 4 04-09-2003 05:46 PM
