ARC R10W
ARC R10W
Any recommendations on which esc and motor to use in arc r10w??
Serpent 747e works best with 1:8 esc/motor and 3s lipo. Same on arc or should i use 1:10 esc/motor and 2s?
I mostly run Serpent eryx with orca vxx and orca 4,5t.
Will i gain any speed/better laptimes with arc r10w?? Or is it just a waist of money??
Locally the class is referred to as "outlaw" the rules are foam tires, 2s battery and 540 size motor, with a lola style body.
Some people run a 1/8th size esc for heat handling capabilities, but they lose top speed as there is no turbo/boost.
The R10W kit (or conversion) will just allow you to run to the full 200mm width. But there are plenty of people running a regular 190mm TC, just running a narrower track width.
