Old 09-16-2005, 07:19 AM   #1
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default help quasar pro setting
can someone help me..
i have my quasar pro charger version 1 and i have 1700 & 3300 packs... can u tell me what is the right settings for each packs... AMPS, DISCHARGE, TRICKLE, THRESHOLD, ETC...... thanks in advance....
nikkiesteban is offline   Reply With Quote
Old 09-16-2005, 07:38 AM   #2
Before doing anything else, check to see if you have the version 2.1!
Due to a potential safety concern, there is a voluntary recall of the Reedy #611 Quasar Pro Charger.
Two problems, a defective fuse and a program error, make the charger unsafe to use, particularly with high capacity NiMH cells. On rare occasions, an internal component failure, or an external electrostatic discharge event ("Carpet sparks"), can cause the charger to overcharge these battery packs. This can result in leakage, overheating, or even explosive separation of cells in the pack.
This recall applies to all #611 Quasar Pro Chargers manufactured up to March 1, 2004. They can be identified by any of the following:
1) Display shows "QUASAR PRO VERSION 1.0" when first turned on.
2) No barcode label on the underside of the charger.
3) A barcode label on the underside with the numbers "611" or "611A".
If you have this charger, you must discontinue its use immediately, and contact Associated Electrics, Inc., to arrange for corrective service at no charge to you.
Corrections for the problem have been developed and tested. New Quasar Pro chargers, and chargers that have been corrected, are designated #611B, and display "Version 2.1" when turned on.
RickyIS300 is offline   Reply With Quote
Old 09-16-2005, 08:15 AM   #3
Default help
any tips about the settings.....
Old 09-16-2005, 10:30 AM   #4
Here you go (I have one of these) - for the 3300 only (I don't know 1700 packs):
Amps: 5.0-5.5 amps
Discharge: 20 amps
Trickle: off
Threshold: .03 mv
Cycle: you don't really use
Delay: you don't really use
grazianos is offline   Reply With Quote
Old 09-16-2005, 04:00 PM   #5
Default help
thanks for that one....
any other settings....
Old 09-16-2005, 06:02 PM   #6
The above settings should work for 1700s, just change the battery Mah setting. Are there any other settings you are unsure about?
Old 09-16-2005, 06:41 PM   #7
pme
pme's Avatar
bcoz other says that threshold setting should be 8mv/c.......
if u we're to charge what will u use?
pme is offline   Reply With Quote
Old 11-21-2005, 03:15 AM   #8
Default help
what is the difference between the ver1 of quasar pro and ver2.1???
please tell me... tnx
car setting! jameslow Nitro On-Road 5 02-21-2008 07:59 AM
a little help setting up a M8 cyrrus Electric On-Road 3 06-16-2007 10:21 PM
setting up kurt777 Electric Off-Road 3 02-14-2007 05:32 PM
Toe setting help Xrayskid Electric On-Road 10 06-12-2006 06:15 AM
Setting foe V One S xax Singapore R/C Racers 7 11-07-2002 06:44 PM
