Old 10-11-2005, 07:21 PM   #16
chicagokenji's Avatar
Default numbers
I just picked up a Integy 16x7 and am seeing you guys post some final numbers when charging your 3300's.
I'm wondering about final voltage numbers. Am I to assume that when the battery finally peaks that the voltage reading my charger gives me...that a higher final voltage is best? I know that with mah my runtime is increased.
What are great final numbers on a GP3300 6 cell pack and what would be crummy numbers?
chicagokenji is offline   Reply With Quote
Old 10-11-2005, 09:00 PM   #17
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi,
LOWER final numbers are best. this number reflects internal voltage. less than 1.5v / cell is great 1.5 - 1.53v is good. i would be dubious about anything over 1.55.
If you equalize your cells well you should easily get 3900mah into 3300's. With the last sets of 3300's I had I was getting 4300Mah into them but they do need to be well equalised.
Chris
crimson eagle is offline   Reply With Quote
Old 10-11-2005, 09:12 PM   #18
doesnt the final voltage depend on what charge rate u r charging at?
qwerty is offline   Reply With Quote
Old 10-11-2005, 11:31 PM   #19
Yes it does change the numbers a little but most people charge at 5 or 6 amps and the numbers won't change too much at those charge rates. Try it and see what the difference is.
Old 10-11-2005, 11:44 PM   #20
James's Avatar
If you are considering the ICE, get the Supernova Competition instead, it's a better charger.. firmware is almost identical, but the supernova has a few more features (20A discharge, backlit screen, etc)...
I find the controls on the supernova way easier to work with than the jog-dial on the ICE (which is easy to fumble settings with)...
I've used both, and own the supernova comp
It's probably a few dollars more, and comes with the temp sensor.
James
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 10-12-2005, 12:05 AM   #21
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
obviously everyone will stand by their charger. my advice to you get what you want. what ever it may be im sure that you would like it.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 10-12-2005, 05:59 AM   #22
chach's Avatar
If yuo get what more people at the track are using, you can at least see what they are getting for results instead of taking a $200 experiment and ebaying it.
chach is offline   Reply With Quote
TD: RC18mt RTR, LRP Comp Charger, (2)GP4200 Matched for Lipo Charger/Battery...LOOK!! smarking1212 R/C Items: For Sale/Trade 7 10-08-2008 04:25 PM
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 11:33 AM
Mini-V, Lipo charger, Nimh/Nicd charger, Starter, AIRBOAT CustomTrendzInc R/C Items: For Sale/Trade 2 11-08-2007 03:08 PM
Duratrax IntelliPeak DC Only Mini Pulse Charger & Towerhobbies charger$25.00(Shipped) xsxracing R/C Items: For Sale/Trade 0 10-13-2007 03:51 PM
Integy 16x7v6 Charger (with 30 amp discharge), Tamiya F201, Astro Flight 109 Charger 403forbidden R/C Items: For Sale/Trade 4 05-07-2005 08:08 PM
