Brushless Motor Phases Important To A Motors Performance?
I recently picked up a motor checker and checked my brushless motors. At hand I have a batch of 21.5's such as; D3.5, MMM, R1, Tekin, G-Style, and Orca. I did some timing tests for these motors and came across some motors with A B C phases that were out by only a 1 or 2 degrees. However, I had some motor phases out by 10+ degrees.
For example I've tested a motor with A 23* B 39* C 42*. As you can see there is a big variance in timing at each phase.
Now, does this matter in the motors overall performance?
I did a test on a Team Powers Actinium 21.5 and it was by far the best motor. The phases were A51* B51* C50*. Cant get any better than that. Interestingly, the motor was very smooth and quiet.
Motors with greater variances in timing between phases sounded rougher and louder.
So it is time the next generation ESC's do detect the timing of the sensors and put those parameters into the program for an optimised control.
delete.
