Old 10-13-2014, 08:11 AM   #1
Trader Rating: 29 (100%+)
Default New to 1/12 electronics help please
My curiosity after seeing the 1/12 cars got the best of me and I ordered up 2015 x12.
I need some help choosing electronics for it. I see people like the futaba 9650 servo. Is a Savox ok? I just have a bunch of other Savox already.
1 cell esc?
1 cell batteries? Maybe a dumb question but can I use half a saddle pack?
Any input would be greatly appreciated
branover is offline   Reply With Quote
Old 10-13-2014, 08:14 AM   #2
One more thing.
I'm also new to foams. Seems I should have tire truer?
Old 10-13-2014, 08:17 AM   #3
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Most use futaba since it's cheap and a good servo. As long as the savox is a mini you'll be fine. Match up the specs.
12th scale is ran using 1 cell packs.
nitrobeast is offline   Reply With Quote
Old 10-13-2014, 08:27 AM   #4
oeoeo327's Avatar
Trader Rating: 74 (100%+)
1 cell esc?
Servos - Buy the Futaba 9650. Excellent servo for 1/12 - they don't get much better when it comes to accuracy and reliability, which is really important in 1/12 racing. If you already have the Savox servo, by all means use it, but the 9650 is one of the best options.
ESCs offer a lot of options - Orca and Hobbywing make 1S ESCs, other ESCs designed for 2S use can be used in conjunction with a voltage booster (more convenient) or a receiver pack (more weight, but more reliable). Personally, I prefer the receiver pack over the booster - when using a receiver pack, make sure that you set the ESC to operate in a 1-cell mode, or remove the red lead from the connector going to the receiver.
Batteries - there are many choices for 1S batteries, with no real standouts. Look for good capacity (7000mah is the norm nowadays), and pick up the battery of your choice. Stick to batteries using 4mm bullets, as space underneath the body of any 1/12 car is at a premium. Use low-profile solid bullets when wiring the ESC for best results. Using 1/2 a saddle pack, while physically possible in most cases, won't fit in the car properly and isn't recommended.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 10-13-2014, 08:30 AM   #5
oeoeo327's Avatar
One more thing.
Tire truer is a "must-have" item in 1/12. Ofna makes an affordable manually operated truer with more than enough power to get the job done. Add a CRC "All in 1" truer adapter, and you'll be in business.
Old 10-13-2014, 08:53 AM   #6
I have an orca esc and a viper. Both rated for 2 cell. Can you recommend a voltage booster to use? I'd prefer to not but a new esc but I want it to be correct also. If a new esc is the better option than that's what I'll do.
Old 10-13-2014, 09:03 AM   #7
oeoeo327's Avatar
When I used boosters, I used the TQ Racing booster - you'll have to order direct from the manufacturer to obtain one, but they were the best choice of the boosters that were readily available:
http://www.tqcells.com/TQBOOSTER.htm
Old 10-13-2014, 09:09 AM   #8
orca speedos and EA for batteries= a winning combnation!!
John Birmele
JohnBirmele.com
John birmele is offline   Reply With Quote
Old 10-13-2014, 09:13 AM   #9
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
1 cell esc?
The answers to many of the questions you will have
http://www.rctech.net/forum/californ...ll-so-cal.html
That new Reedy BlackBox esc is worth a look
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-13-2014, 09:29 AM   #10
I'm leaning towards getting a 1s esc. Trying to find an orca but they're hard to come by. Thanks for all the help so far
Old 10-13-2014, 09:44 AM   #11
Peakki's Avatar
There is also Team Orion Vortex R10 Pro 1-2S version that works really well with 1S. It is small and lightweight. Hobbywing has V3.1 1S (only 1S) also, as also V2 120A 1S (big and heavy but works good).
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 10-13-2014, 09:55 AM   #12
EA Motorsports-Xray-Orca-BSR Tires-Hudy
Sean B. is offline   Reply With Quote
Old 10-13-2014, 06:10 PM   #13
bigcracing's Avatar
Trader Rating: 32 (100%+)
Hobbywing 1s 3.1 and get the program box and for battery SMC has what you want and use the futaba servo you will be happy. Look in the classified for a tire truer. Tires for the car stick with crc you can't go wrong.
bigcracing is offline   Reply With Quote
Old 10-14-2014, 11:07 AM   #14
So I'm looking at tire truers. Probably taking the Hudy out of the mix based on price. I'm leaning Ofna for availability. Should I go with the manual or automatic version?
Old 10-14-2014, 11:14 AM   #15
bigcracing's Avatar
Automatic is better I have done both and kept my automatic
