Old 09-14-2005, 06:52 PM   #1
wolfman76's Avatar
Default REEDY MVP STOCK
Why do these motors run so bloody hot??? I have the right rollout/gear ratio for my track. I'm still using the standard springs that came with the motor, i've cut the comm but i don't think this would help. I've even installed a fan that blows air over the comm but still runs HOT. Any help would be appreciated.
Cheers
Mick
Downunder
wolfman76 is offline   Reply With Quote
Old 09-14-2005, 06:53 PM   #2
josh69162's Avatar
Send a message via AIM to josh69162
Is your drivetrain binding?
-Josh
josh69162 is offline   Reply With Quote
Old 09-14-2005, 06:55 PM   #3
wolfman76's Avatar
No
Old 09-14-2005, 07:01 PM   #4
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
The MVP gets hot no matter what you do to it. Short of telling you to buy a new motor (Monster stock or ROAR Stock), I don't have too many suggestions. It's never been a fast or efficient motor.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-14-2005, 07:11 PM   #5
jodywk's Avatar
I have used the motor with success on small, tight tracks try narrowing the face of the brush this should help.
jodywk is offline   Reply With Quote
Old 09-14-2005, 07:25 PM   #6
wolfman76's Avatar
Thanks for the info, I think it's time to buy some Monster stocks.
Cheers
Mick
Old 09-14-2005, 08:37 PM   #7
koabich's Avatar
Send a message via Yahoo to koabich
Narrowing the brushes on this motor will make it run even hotter and make gearing absolutly crutial. Even when geared perfectly with narrow brushes, the motor runs so hot it will show a considerable drop in performance less than half way into the race. To get an MVP with narrowed brushes to work, you have to use the dry-ice trick or the peltier cooler before the race in an attempt to make the motor as cold as possible (without freezing it). Even with this method, it will still come off the track incredibly hot but you will only notice a slight decrease in performance toward the end of the race if you notice any at all.
I spent a long time getting this motor and brush combo to work and with a lot of help from Big Jim and Paradigm Racing (they cut brushes fspecifically for this application). While an MVP with narrowed brushes was faster than an MVP with full faced brushes under almost all circumstances, there was unfortunately no instance where this motor/brush combo was faster than a Monster Stock. And the Monster Stock is 1,000,000 times easier to work with.
Bottom line give up on the Reedy and go with Trinity or Epic based stock.
koabich is offline   Reply With Quote
Old 09-15-2005, 06:53 AM   #8
tex1's Avatar
Send a message via Yahoo to tex1
Talking The gosphel!!
Amen Brother. Try the Epic and you will never go back!
TEX
www.indyrcworld.net
Indy RC World 2.0 - Garland, TX
T&T RC Cars - Plano, TX
(972) 271-4844
tex1 is offline   Reply With Quote
Old 09-15-2005, 07:42 AM   #9
DIMO's Avatar
Default put
Stick an epic arm in it and watch it flyyyyyyy, lol, pity its a hybrid and not legal
And even Big Jim {r.i.p} said that was one of the fastest stocks ever
DIMO is offline   Reply With Quote
Old 09-15-2005, 08:48 AM   #10
The problem with the MVP, is the motor is too good.....
Let me explain.
On the dyno (and no not the fantom dyno, lol) this motor produces very consistent and big power. Much more consistent than say a MOnster or Epic Roar stock will. The problem lies in the mangets. The magnets are way too strong for Stock racing. It cuts down the RPM and heat builds up very quickly. In turn heat = lower laptimes.
Believe me if you could get the heat out of the equation and pick the RPM up about 2000, this would be the motor to run.
We had to run them at the Oval nats this past spring and the TQ was about 2-3 seconds off the track record set with an EPIC Roar stock. So they can run pretty quick if you fool around with them but we figured if we ran Epics or Monsters we would have gained about a lap.
erock1331 is offline   Reply With Quote
Old 09-15-2005, 09:00 AM   #11
"The magnets are way too strong for Stock racing" If this is the case, then is there no way to De-zap the magnets to reduce their strength?? Jonathan
jonny69 is offline   Reply With Quote
Old 09-15-2005, 09:02 AM   #12
Some have tried to reverse zap the can then zap it normally again. This does increase RPM but usually the power loss is too much. At least for Oval it is. Not sure how it would work for On Road.
Old 09-15-2005, 10:37 AM   #13
wolfman76's Avatar
Probleme solved, I have two Team BrOOd Monster stocks on the way.
Thanks for all the replys.
Cheers
Mick
Downunder
Old 09-15-2005, 10:45 AM   #14
AM03GT's Avatar
i've been out of the stock game awhile and so i run the monster just to keep the motor equation out of me trying to get back into the groove. but when i was doing well, i would experiment with my MVP...
i used narrowed brushes or full faced brushes with a drill hole. both worked relatively well and better than a standard full face brush configuration. i found that at least on fast high speed layouts where you barely roll off the throttle, it was very fast... its definitely a screamer on the straight, if you can maintain infield speed its a goodie.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Reedy MVP Stock Motors OTE_TheMissile R/C Items: Wanted to Buy 16 09-18-2007 03:17 PM
New REEDY Stock Motor!! BobbyDoyle Electric On-Road 12 04-02-2006 09:03 AM
Losi xxx-t LRP Reedy MVP stock hollisst R/C Items: For Sale/Trade 2 04-12-2005 05:32 PM
New Reedy Stock Motor Calvin Ng Electric On-Road 19 07-01-2003 10:07 AM
Brand New Reedy MVP Stock Motors!!! SirSpeedy R/C Items: For Sale/Trade 15 02-04-2002 10:37 PM
