Old 09-14-2005, 07:39 AM   #1
LosiSuperTruck's Avatar
Trader Rating: 18 (100%+)
Default Must Need Hop-Ups for the JRX-S?
Hi all,
I am getting a JRX-S and would like to know what are the "must need" hop-ups for it? Specifically, is there any parts that seem to break more than others? For example, the NTC3 has a crappy diff case design and the case is easily broke. Any after market parts that are recommended?
LosiSuperTruck is offline   Reply With Quote
Old 09-14-2005, 07:56 AM   #2
1fastdude's Avatar
Trader Rating: 15 (100%+)
Different springs, sway bar kit, offset hubs, Rubberneck Bumper.
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 09-14-2005, 07:59 AM   #3
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
The biggest things are a P-dub front bumper and BK-Pooky brackets. After that its stuff you'd want with any car. Springs, sway bars, ect ect
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 09-14-2005, 08:05 AM   #4
Still Bill's Avatar
Go with David's recommendation.
With the BK/PK shock brackets you only need 10.5/12.5/15.0 springs.
New f/r JRX-S arms are due out soon; so, keep those spares to a minimum.
4 degree front hubs and 0 degree rear hubs.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-14-2005, 08:40 AM   #5
Thanks for the reply.
Forgive my ignorance, but what is a "BK-Pooky bracket" and where do I get it?
Old 09-14-2005, 08:54 AM   #6
One more question,
Is the Rubberneck and P-Dub bumper the same thing? I can't seem to find the Rubberneck one.
Old 09-14-2005, 08:56 AM   #7
highwayman's Avatar
what did they change on the arms?
highwayman is offline   Reply With Quote
Old 09-14-2005, 08:58 AM   #8
cartmen34's Avatar
They are incorporating the BK Bracket mounting points in the mold of the arm. I'm not aware of any other changes.
cartmen34 is offline   Reply With Quote
Old 09-14-2005, 09:07 AM   #9
highwayman's Avatar
great ! any timetable on the new arms?
Old 09-14-2005, 09:30 AM   #10
Yes the bumpers are the same. The word on the arms is I guess sometime soon.
Old 09-14-2005, 09:30 AM   #11
Seems this got overlooked with all the excitment about the new arms
Old 09-14-2005, 09:35 AM   #12
Click on the Pooky link in my signature. He's the man who makes them. I'm sure he can get your setup. They are just brackets that allow you to move the shocks out on the arm so you can run a softer spring.
Old 09-14-2005, 03:21 PM   #13
robk's Avatar
Trader Rating: 22 (100%+)
The aluminum battery tray is nice as well..not sure if it was mentioned..
Old 09-14-2005, 04:24 PM   #14
2-Bad's Avatar
Trader Rating: 24 (100%+)
And the "Josh Nueman" setup......
You will need additional roll-center shims, and Dodge Stratus 3.0 AP body.
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 09-14-2005, 05:02 PM   #15
Juan Valdez's Avatar
LosiSuperTruck - Much of what has been recommended so far is mostly for rubber tire racing. Since you didn't mention if you run rubber or foam (on carpet), I thought I'd pitch in about running the car with foams. For the springs you will probably want to start with 50 or 60 lbs. front springs and 17.5 to 25 lbs. rear springs. You can use the BK brackets in the rear of the car if you want, but not the front (with 28mm wide foams). And you may want 6 degree front c-hubs, and off-set rear hubs.
For those wondering about the new arms w/ the BK mount in them, I would guess they are close. Todd Hodge said sometime this month (I think), and I saw a set on a team driver's car this past weekend.
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
