Old 09-15-2005, 01:15 AM   #16
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Also wanted to add, I am chasing 7-9 singles only. (run on a pretty large asphalt track, rubbers and pretty hot conditions)
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 09-15-2005, 03:04 AM   #17
If its a big track don't waste time on the 9 turn.When Hara was in town for a demo race...He used a '6 TURN' on what I call a medium sized track!
So I think a 7-8 turn would be good for your application.
Ben.C is offline   Reply With Quote
Old 09-15-2005, 05:32 AM   #18
Thanks for the info Ben C. Much appreciated.
Old 09-15-2005, 05:43 AM   #19
Spud_J's Avatar
We have had a few issues in the UK with the epoxy coming off but to be honest it's usually when they are timed with more advance than necessary, other than that no problems.
For larger tracks I think you will struggle a little with duration on the 6's and 7's unless your very throttle friendly! We have three Arms direct for Oscar which are 6's and 7's with the groove but to be honest we run a off the shelf Reinhard 8x1 pretty much everywhere we go because they are so durable. BTW it is only the 12 turn in the Reinhard range that has the grooved stack.
Our usual setup on that is
8x1 Reinhard
Sprint edge brushes
16degrees timing (inbetween 2nd and 3rd mark)
MR032 springs which are the softest Inox versions - Pt Number 41382
Gearing between 7.8 and 8.2/1 depending on circuit size
We finished 3rd in the A main at the last UK mod National, behind Chris Grainger and Craig Drescher and in front of Andy Moore with that very motor and it was a pretty open and flowing circuit....certainly were not short of horsepower and it had one skim and one set of brushes all day.
HTH
Steve
Spud_J is offline   Reply With Quote
Old 09-15-2005, 05:59 AM   #20
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
All of our armatures are drill balanced, from 6-19 turns, and each armature/motor comes with a "LIMITED LIFETIME WARRANTY".... If your interested, contact Scott Harris of Harris R/C as they are the exclusive importer of DC Motorsports into Australia...
Curtis,
Curtis Schlaht is offline   Reply With Quote
Old 09-16-2005, 10:30 PM   #21
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Got this from Team Orion.
Blue - 5mm armature web, enduro brushes, off-road winds
Black - 4mm armature web, enduro brushes, touring winds
Green - 4 mm armature web, sprint brushes, off-road winds
Purple - 4mm armature web, Sprint brushes, touring winds
The Blue V2 is the weakest of all but is more economical. Lasts longer in between rebuilds.
Sean
Team Duratrax is offline   Reply With Quote
og bj4 info needed afish Electric Off-Road 2 04-13-2008 09:21 PM
help info needed cookiebitch Racing Forum 0 05-03-2007 06:58 PM
19t Info Needed Racer X Electric On-Road 10 11-22-2005 10:08 AM
RB C4 .21...info needed 6Cuda6 Onroad Nitro Engine Zone 0 08-11-2004 05:58 AM
T4 info needed snopro31 Electric Off-Road 8 04-27-2004 10:33 PM
