Old 09-13-2005, 06:07 AM   #1
Default esc current for 540 motor
hi, what is the required current that i need my esc to do to run a 540 motor ? thanks
qwerty is offline   Reply With Quote
Old 09-14-2005, 12:09 AM   #2
Hi, this depends on motor very much. Which type 540 motor did you use? Stock 27t, super stock 23t, or modified 9t? All this motors require different currents? Please give more info...
deepfree_z is offline   Reply With Quote
Old 09-14-2005, 12:31 AM   #3
Usually when you buy an ESC,you got to check out how many turns can the ESC take.
Most of the top of the line ESCs can take unlimited turns,some can take till 12 turns and some even more...
Usually a 10 turn can draw more than 10 amps.So when you select an ESC check the rating of how many turn can the ESC go down to?
If you us a 9 turn on an ESC which can only take 12 turns,you're goin to blow that ESC.
Ben.C is offline   Reply With Quote
Old 09-14-2005, 01:35 AM   #4
a rs sport tuned 540 motor... at which point does going to a higher amp draw does it not become benificial coz the 540 cant use the power anyway?
Old 09-14-2005, 01:56 AM   #5
Send a message via ICQ to rcnewb2004
Basically speaking, try to find the number of turns your motor has, and then ppl here can help you better.
But from the looks of it, looks like you are running stock, so any esc that takes a 19 turn, you will be ok.
rcnewb2004 is offline   Reply With Quote
Old 09-14-2005, 02:42 AM   #6
ford_racing's Avatar
Send a message via MSN to ford_racing
for a 540 Black motor all you need is a TEU101BK, the ESC handles mre than enough current for the rs 540.
Every ESC on the market is able to handle that motor, all are able to give it more than enough amps, havng dynoed several at 3v they were all drawing approx 1.3 amps
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 09-14-2005, 02:49 AM   #7
i am going to get a gt7 ... yeah i know a bit overkill... but.... it asks to install motor capacitors... how do i go about doing that on a the 540 mubachi motors?
use 3 capacitors
1 to positve to negative
1 positive to the outer can; and
1 negative to the outer can
is that right? or do i not need it for stock motors? i never required it from my sport esc..
Old 09-14-2005, 03:19 AM   #8
10amp is nothing !
a 10 turn can draw even 100amp !
e_lm_70
e_lm_70 is offline   Reply With Quote
Old 09-14-2005, 03:41 AM   #9
pyrosian's Avatar
The capacitors are used to help stop glitching, in a 540 silver can or a RS-540 Sports Tuned they are all ready installed within the can itself.
pyrosian is offline   Reply With Quote
Old 09-14-2005, 03:53 AM   #10
[QUOTE=qwerty]i am going to get a gt7 ... yeah i know a bit overkill... QUOTE]
Getting a good ESC is never an overkill,take it as a investment where next time as your skills gets better and your need for speed is up,you just need to get a faster motor and not another faster motor and ESC.
And a top grade ESC has lower IR than lower spec ESC.Thus givin you better punch.
Old 09-14-2005, 09:34 AM   #11
Yep. If you are serious about rc, a good esc is a long term investment. It will run ALL motors better than a cheap one (will run cooler, with more punch, better feeling). It will save money on the long run, because sooner or later you will wanna try a hot modified.
Itchy is offline   Reply With Quote
Current Drain Jye Nitro On-Road 1 07-21-2005 11:27 AM
LRP 7.1 Current Limiting Module MadMikeB Electric On-Road 2 06-16-2005 06:06 AM
Please help.The good and the bad of current cars. speed2004 Nitro On-Road 0 07-06-2004 03:10 PM
Clod Buster Motor Current elglg Monster Trucks 0 01-10-2004 05:47 AM
