Old 09-12-2005, 08:20 PM   #1
Default did i damage my battery?
hi i have a gp3300 stik pack... i acidentally short circuited the batteries... after i charged, the bananna clips touch ends a bit for about a second... are the batteries going to lose some life to them?
what should i do now? put in freezer? any tips appreciated
noobie is offline   Reply With Quote
Old 09-12-2005, 08:21 PM   #2
josh69162's Avatar
Send a message via AIM to josh69162
Seeing as how your name is "noobie," I would say no. Although you do need to take care of your batteries, the damage (if you can really call it that...) will not be noticeable. And I think your safe to go ahead and run the battery down like you normally would. I wouldn't lose sleep over it.
-Josh
josh69162 is offline   Reply With Quote
Old 09-12-2005, 08:32 PM   #3
Yes,you have just shorten the lifespan of your cells by a bit by doing that.Now your cells could have higher internal resistence.But if you're not racing and just bashing around,I would worry too much about it.If its a race cell,,it would probably downgraded to a practice cell.And I would heartache a little while....
But try to be careful the next time,I believe everyone who has been in this hobby has shorten more then 1 pack in his RC-ing life.
Ben.C is offline   Reply With Quote
Old 09-12-2005, 08:57 PM   #4
josh69162's Avatar
With all due respect, do you really think he shortened the life of his pack? I sure don't. And if he did shorten the life, it sure wasn't enough to automatically degrade is pack to the "practice" level. It was being shorted for one second. If you can honestly feel the difference from that, you deserve to be sponsered...
-Josh
Old 09-12-2005, 09:12 PM   #5
ChadCapece's Avatar
I've got about 3 packs and a few swollen cells that agree with you
ChadCapece is offline   Reply With Quote
Old 09-12-2005, 09:20 PM   #6
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi,
I seriously doubt you did any long term damage to the cells if it was an instantaneous thing. inside a stock motor which has laydown brushes there is a small amount of time where the motor is shorted. This is deliberate and effectively shorts the cells. You will be fine.
Chris.
crimson eagle is offline   Reply With Quote
Old 09-12-2005, 09:34 PM   #7
ok thanks... i discharging now and will see if it goes back to same levels....
the short wasnt a hard contact ... just the bannna plugs touched lightly and made a few buzzing noises... happened twice
Old 09-12-2005, 09:45 PM   #8
Send a message via ICQ to rcnewb2004
you are fine. There should be no noticable damage, if you didn't even feel your batteries heat up. And even if they did heat, it would take more than "a second" to do any real damage that is noticable.
rcnewb2004 is offline   Reply With Quote
Old 09-13-2005, 07:00 PM   #9
really dont think you have a problem ... .. just make sure to keep those plugs apart ... Or try Deans ultra plugs . and put one on your charger that way you wont have to worry about shorting your paks .. (just a suggestion )) ... good luck at the races ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 09-14-2005, 08:16 PM   #10
Ghostfit's Avatar
Heck ! ....wat damage ? ....you just ZAPPED your cells, if anything, you should see higher voltage and lower IR. ....pple use to pay $$$$ to buy a battery zapper
....Kid !.....Kid !
Ghostfit is offline   Reply With Quote
Old 09-14-2005, 09:31 PM   #11
Sushi Man's Avatar
Send a message via AIM to Sushi Man
lol Zapped, I think it has to be a little higher voltage, lol like many times more.... but yeah I have done the same thing. LOL well one time my batteries shorted on my graphite chassis and smoke came out. That might lower the performance of the battery but just a little zap? its fine. I still use my Zapped GP3700 from japan and they have more punch then the normal matched and I shorted them with the banana plugs.
Sushi Man is offline   Reply With Quote
Possible engine damage? kilrbzz Nitro Off-Road 6 09-14-2007 09:01 AM
Did I damage my batteries? M-Technic Electric On-Road 3 09-10-2007 12:00 PM
water damage jkgilliam1 Electric On-Road 11 09-19-2006 04:21 PM
Water damage ? thahookup Rookie Zone 9 05-30-2006 09:59 PM
Way to prevent damage??? Greenbox Onroad Nitro Engine Zone 7 08-11-2005 08:29 PM
