Old 09-25-2014, 04:47 PM   #16
Ok....wow a lot of movement on this today...thank you everyone for your replies.....this is the best I can do to assist in the info requested......
Car- F104 V1 Pro
Toe in/out - 0 degrees
Ride height - 3.5F/3.5R
T-Bar - thinnest ( not sure what the measurement is )
Front springs - silver
Rear shock spring - white tamiya
Rear shock oil - not a frickin clue ( used car )
Exotek wheels
571/572 pits
Brakes set at 96%
ABS - not on
No damper tubes because it's a V1 but the friction plate is very loose
Body is and F60
Yes the carpet is approx 26 years old and yes I am getting better traction with the tamiya tires that are mounted on tamiya wheels.
So that's the best I can do......I have been told that I shouldn't expect very good performance out of that chassis as it is not all that good for rubber. I hope I don't need to build a new car to put between these tires that I own.
Thanks in advance for any help!
Shaun Barron.
Big and Important Titles
2 lines of sponsors!
Cuz Big and Important Titles and 2 lines of sponsors are way cool
Shaun B22 is offline   Reply With Quote
Old 09-25-2014, 04:51 PM   #17
tdu verney's Avatar
Default F1
Car- F104 V1 Pro
Exotek wheels
571/572 pits
Brakes set at 96%
ABS - not on
Body is and F60
try some toe out 1.5 to start... then add 1mm shim under the rear upright ball joint...
tdu verney is offline   Reply With Quote
Old 09-25-2014, 04:53 PM   #18
tdu verney's Avatar
Originally Posted by Serzoni View Post
F60 and Mclaren, usually. You can use the lower part of the Mclaren wing with the upper part of the 2012 wing.
Anyone tried 3 racing high down force front wing?
Old 09-25-2014, 09:11 PM   #19
robk's Avatar
Trader Rating: 22 (100%+)
Ditch the silver front springs that is a huge problem. Use black or like a .020 associated or .50mm CRC.
Also, the t bar cars are awesome on rubber, who ever told you that is mistaken.
The latest TCS trip to japan was won with an original F104 t bar car.
Old 09-26-2014, 10:50 AM   #20
JayL's Avatar
YES YES YES to ROBK
I have been running the AE .016 front springs
and my F104x1 is always the baseline when I try a new car, that car just flat WORKS on asphalt!
MOD: A800X LRP FlowX X22 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
