Like Tree263Likes
GT12 Racing
Old 11-20-2021, 04:13 PM
  #586
TonyD.'s Avatar
Trader Rating: 41 (100%+)
change to the spool and it will shorten up the rear so the wheels fit inside of the body.
TonyD. is offline
Old 11-20-2021, 04:46 PM
  #587
gwc
Doing that will also drastically change the handling characteristics.
gwc is offline
Old 11-21-2021, 04:24 AM
  #588
TonyD.'s Avatar
yes it will make it handle better in and out of corners.
TonyD. is offline
Old 11-21-2021, 05:11 AM
  #589
gwc
Wider Track Width: Both front and rear. The wider the car, the less lateral weight transfer and the less traction rolling you will have. In High bite conditions, you want to run wider. An added benefit of the wider rear is that it will put more leverage on the side springs making them act softer.
Buckland and Brian10811 like this.
gwc is offline
Old 11-21-2021, 09:05 PM
  #590
TonyD.'s Avatar
trust me you will get better cornering with a spool.
TonyD. is offline
Old 11-22-2021, 03:23 AM
  #591
Trader Rating: 67 (100%+)
Default Gt12 gears options
Hey guys, I’ve been racing gt12 on rubber for awhile. We run 1s,usgt motor,sjt, fixed gearing... anyways we’re looking at splitting the class by doing a fixed gear class and open gear class and using the fixed gearing more like a sportsman/ newer drivers.. I’m looking for a good place to start gearing wise. Thanks
rcracersb is offline
Old 11-22-2021, 03:51 AM
  #592
gwc
That depends mostly on the track & motor, we run on a black CRC carpet medium size track 21.5 motor rollout of 82.7 to 86.4
Tire dia. (41) x pinion (45-47) x 3.14 / 70 (spur) = rollout (your performance may vary) 😅
gwc is offline
Old 11-22-2021, 04:37 AM
  #593
We use that same USGT spec motor on the rubber tires. This will sound crazy but my current gearing is 63 pinion, 67 spur. The track is 90 x 40.
old_dude is offline
Old 11-22-2021, 04:48 AM
  #594
gwc
121.0 rollout = mind blown🤯
LonnyJ1950 likes this.
gwc is offline
Old 11-22-2021, 06:50 AM
  #595
come to the Fla. with open motors, open gears and foam tires. .We'll be glad to help you on the gearing for our outdoor and one indoor (carpet Black)
glennhl and phatboislim like this.
BullFrog is offline
Old 11-22-2021, 06:55 AM
  #596
im in black carpet with usgt motor. Track is like 40x60. One long straight rest is pretty technical but fast
Old 11-22-2021, 08:23 AM
  #597
gwc
Lived in FL from 1959 to 1973 it was a great place to grow up back then.
gwc is offline
Old 11-22-2021, 08:38 AM
  #598
gwc
gwc is offline
Old 11-22-2021, 01:43 PM
  #599
Is that ball diff or spool?
Friulimotosport is offline
Old 11-22-2021, 03:03 PM
  #600
Hi, what is a fixed gearing class? Does everyone need to run the same tooth pinion & spur?
dangdude is offline
