tc4 throttle not working >
Old 09-20-2014, 05:47 PM
Default tc4 throttle not working
Hello all today I was charging my 3000mah 7.2v onyx battery and I left it on for to long and the battery was HOT! The battery is cool now but when i put it in my car it will run for a few seconds then I get no throttle. Only steering.im fairly new to electric rc please help thank you!
NewXGen is offline
Old 09-20-2014, 05:54 PM
Esc led shuts off when I hit throttle.....
NewXGen is offline
Old 09-20-2014, 08:10 PM
Now the car will only steer left or right no throttle at all. The esc green light turns bright at half throttle and shuts off at full throttle. No power to the wheels at all...
NewXGen is offline
Old 09-20-2014, 08:47 PM
Geezatec's Avatar
re-calibrate your TX to ESC.
Geezatec is offline
Old 09-20-2014, 09:41 PM
thank you for the reply! im not sure how to do that. wouldyou mind giving me tip? its a tc4
NewXGen is offline
Old 09-20-2014, 10:24 PM
this sucks....google isn't helpful at all....... its a AI Digital ESC and I cannot find anything in the manual on how to reset the esc or whatever. all it says is "no throttle = speed control out of adjust....reset speed control using your instruction manual" and when I go to the manual it doesn't say anything about a speed control
NewXGen is offline
Old 09-20-2014, 11:06 PM
its working again! disconnected the motor from the esc and now its working! anyone have any idea as to what might have happen feel free to give your input I wanna learn as much as I can! thanks!
NewXGen is offline
Old 09-23-2014, 07:53 AM
Geezatec's Avatar
Not accustom to the lower type ESC's. More into hi-end ESC's like Tekins & Novak. It sound like you're running a brushed motor, cuz of battery you're using. As for using AI Digital ESC search AI Digital ESC Manual in RCDocument .com. It will open several ESC Manuals. I looked at a few of them, and it Calibrates automatically. Secondly, Watch what setting you have on your charger, 3000mah(3amps) you charger should be set at. Most NiMh can be set 10% higher, but if you're still a rookie, I would charge more then the battery is rated for. Heat of battery is a bad thing, Monitor it, good charger shut itself off and drops to .5amps(trickle charge).
Geezatec is offline
