Old 09-11-2005, 09:14 AM   #1
zax
zax's Avatar
Default GLITCH..
Does AM transmitted and receiver make the servo glitch seriously? what can i do to make it not glitchly?
zax is offline   Reply With Quote
Old 09-11-2005, 10:20 AM   #2
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
any radio can glitch.. you need to find out what caused it to do so..
burbs is offline   Reply With Quote
Old 09-11-2005, 02:48 PM   #3
Bill Crawford's Avatar
Make sure your motor is clean and has caps this will help with glitching
Bill Crawford is offline   Reply With Quote
Old 09-11-2005, 09:44 PM   #4
Hi,
Basically AM or ampilitude modulation is more prone to glithes than thier FM conterparts.Make sure all power wires,eg.any wires, is far away from your antenna wire,motor comm cut and new brushes and also importantly is the caps.And by the way,are you using metal gear servos too?During the servo turns,the movement of the metal gears moving together rubbing each other will create frequency niose also.
Hope this helps.
Ben.C is offline   Reply With Quote
Old 09-12-2005, 12:29 AM   #5
zax
zax's Avatar
Originally Posted by Ben.C
Hi,
Hope this helps.
THANKS.. i am using plastic gear servo..i am using super stock rz motor with schottky diode and motor capacitor..i place the anntena and reciever far away from the wires and the esc, it oso causes glitches.
Old 09-12-2005, 12:45 AM   #6
Ok,how about your motor??Is it a new motor?? OR quite a used one? A worn out motor(ie,worn out comm and short can throw away brushes) can cause a lot of arching and produce a lot of frequency noise.
Or another problem could be that your crystal is damage.Go try to replace your crystal and see whether does it help.
If not I recommand that your change your radio using FM,and try using 40MHz.It'll solve your glitching problems.
Old 09-12-2005, 01:20 AM   #7
zax
zax's Avatar
i have been using this motor for 4 months for competition and practicing..i also cut the comm..the brush is not very short but it still can use it.. i not sure whether the crystal is damage.. changing my radio using FM cost huge amount money for me.. When i steering half on my left and right, the servo glitch like hell.. wat can i do to make my servo not glitchy by not buying a new FM radio..?
Old 09-12-2005, 01:47 AM   #8
Send a message via ICQ to rcnewb2004
you can try borrowing someone else's crystals, see if the problem persists.
if your motor has proper capacitors installed, you can try those black radio noise reducing thingies which i don't know the name of.
Does your glitching happen even when your car is on a stand (not running on the track?)
rcnewb2004 is offline   Reply With Quote
Old 09-12-2005, 01:53 AM   #9
zax
zax's Avatar
my servo glitch only..when i steeing my car half (1/2) left and right, the servo start to glitch..when i neutralise the steering..it won't glitch..it glitch when i steering (1/2) half..
Old 09-12-2005, 05:12 AM   #10
BrainTeased's Avatar
try replacing your steering servo with another servo and see what happens or disconnect both tie rods off and move the wheels side to side to see if there is any binding in your steering system. the servo may glitch because something is binding and the servo was not made to operate at such torque levels.
im only guessing here but i hope it helps
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-12-2005, 05:18 AM   #11
zax
zax's Avatar
SAME..I REPLACE TO ANOTHER SERVO..IT ALSO GLITCH..i check already.. there is no binding..i guess is the AM problem..
Old 09-12-2005, 01:22 PM   #12
Replace the crystals, borrow from someone else.
Have you tried doing this elsewhere? (like does this happen at home?) sometimes too many radios can cause weird problems.
Old 09-20-2005, 05:05 AM   #13
zax
zax's Avatar
i have tried doing this at home and track...it also glitch..
Old 09-20-2005, 09:26 AM   #14
Get a new or 2nd hand FM radio!!!
Old 09-20-2005, 01:26 PM   #15
Use someone else's spektrum reciever and transmitter. that thing is nearly glitch proof. if it still glitches, keep the spektrum and throw your car away.
FX Pro Glitch racing_jason Electric On-Road 3 04-03-2009 05:16 PM
DX2.0 Glitch? monkeyracing Radio and Electronics 3 03-25-2008 11:51 AM
Glitch tkhoo Malaysian R/C Racers 6 08-21-2004 10:15 AM
MX-3 Glitch tridagger Electric On-Road 7 01-25-2004 06:55 PM
Esc Glitch???? Steevo Electric On-Road 16 05-07-2003 06:22 PM
