DIY RC tire Balancer with spare parts from a slash? >
Old 09-10-2014, 06:37 AM
Default DIY RC tire Balancer with spare parts from a slash?
I made this DIY tire balancer with spare sparts from a slash and it seems to work pretty good.
I used golf lead tape as tire weight it work much better than clay.
Skip to 11:35 to see it in action.
+ YouTube Video
joerc2013 is offline
Old 09-10-2014, 09:29 PM
Microtome's Avatar
Default Thanks for sharing
Dang I just bought a tire balancer too. Either way I appreciate you taking the time to show us what you came up with.
Microtome is offline
Old 09-10-2014, 10:58 PM
This is what i made from a damaged Topcad set up station, a spec r motor fan bracket, some spacer, and of course, a up right.
[/URL]
TXXT is offline
Old 09-11-2014, 03:46 PM
(0000000000)'s Avatar
Looks like you used quite a bit of glue. The blotchy crust on the rim is excess CA. Usually 4 drops can coat & seal an entire tire to a rim.
(0000000000) is offline
Old 09-11-2014, 04:27 PM
I use one of these. very accurate. been using it for a long time.
http://www.horizonhobby.com/products...alancer-DUB499
dragonracing is offline
Old 09-11-2014, 05:34 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
this type work very well. there is as little friction as it just about possible, so the tire can be balanced quite a bit better than a bearing set up (which has still a lot of friction compared to a single rod rolling on a little ledge)
ThePanda is offline
Old 09-11-2014, 06:09 PM
Always thought that balancing tires was a good idea. Especially works great on off road. But I notice when I tried it on TC wheels, it goes off balance when the insert shifts inside. How do you guys get around that?
redbones is offline
Old 09-11-2014, 06:19 PM
not to sure bout that. i run vintage tires (vta class). so im not sure how its going to work with those. im still waiting for my lead to show up. did not do it all summer but going to try this winter on carpet.
Old 09-12-2014, 01:47 PM
ThePanda's Avatar
You can glue the inserts into the inside of the wheel with a few drops of glue, or use thin double sided tape.
ThePanda is offline
