Old 09-08-2014, 11:57 PM   #1
OttoKrosse's Avatar
Default Where can I buy 3,000,000 CST diff oil
Looking to get thicker oil for the front diff, and can't seem to find 3 million cst diff oil that I'm looking for.....any help out there?
Diff currently holds 2.5 million cst but was told I should be running something heavier by a local racer. Don't want to run wax ear plugs so please save that advice for someone else.
FYI, I'll settle for 2.5 million diff oil if that's all I can get, but prefer using heavier oil.
Thank you in advance.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
Old 09-09-2014, 12:09 AM   #2
Odin544's Avatar
Trader Rating: 93 (100%+)
Never seen or heard of 3 million. There are some silicon putties though I think. I'll see if I can find it.
edit: http://www.reflexracing.net/RSD-Sili...ty_p_2204.html
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 09-09-2014, 12:10 AM   #3
JimmyMac's Avatar
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-09-2014, 12:18 AM   #4
OttoKrosse's Avatar
Damn, I just got an order from them, guess I should have asked this question a week ago. ......
Can anyone estimate the CST rating of this RSD putty without adding oil?
Thanks for the help!!!
Oo=00=oO
Old 09-09-2014, 08:16 AM   #5
stormridersp's Avatar
With that density, you might just as well glue the diff up. From 500k up, its already very locked.
stormridersp is offline   Reply With Quote
Old 09-09-2014, 08:30 AM   #6
Odin544's Avatar
There is a big difference between 2.5 mil and a spool.
TriCitiesRC.com
Old 09-10-2014, 12:10 AM   #7
Geberit's Avatar
Yes! Also if you compare a diff with puty and spool. A diff with puty can be so hard you can't move it with hands but on the track you can feel the difference compared to spool big time
Geberit is offline   Reply With Quote
Old 09-10-2014, 10:13 AM   #8
Rick Hohwart's Avatar
The amount of fluid in the diff will affect how it feels. A completely full diff with 2.5 million will feel very stiff so be sure that it is filled completely or with as little air as possible.
It will never feel as heavy as silicone ear plugs or putty, but it does not have to be that tight.
I have never seen silicone fluid heavier than 2.5 million.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 09-10-2014, 10:29 AM   #9
This will help in a big way to get rid of any air you have in your diff. With oil that thick the air bubbles can sit in between the gears. Speeds up the process of building x10
http://www.tqrcracing.com/shop/produ....asp?p_id=1597
I use it a couple times when I'm building a diff and removing air. I turn the gears a little between pumps.
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 09-10-2014, 11:01 AM   #10
C@T's Avatar
Even if you are able to fill your diff completely without the smallest buble inside, you will find air inside having used it for a certain time.
The reason for that is that when you operate the diff it will heat up and the oil will expand resulting in a leaking. When it cools down again it will suck air in. thats physiks nobody can get arround.
The oil leaking out of the diff will find a way your outer diff gears and cause them to consume power. by moving the sticking oil arround.
For that reason I do not fill them completely.
C@T is offline   Reply With Quote
Old 09-10-2014, 12:04 PM   #11
OttoKrosse's Avatar
Thank you Rick, and thanks to everyone else that provided advice. It's great to have a community that shares their years of experience!! ....
Oo=00=oO
Old 09-10-2014, 01:03 PM   #12
Odin544's Avatar
Best way to build a diff with thick fluid IMO. Fluid first, then insert the gears.
+ YouTube Video
TriCitiesRC.com
Old 09-11-2014, 02:00 PM   #13
I am new on the sport
Could you please tell the difference between using spool and super tight diff?
Thank you
donnie_p is offline   Reply With Quote
