Old 09-07-2014, 09:26 AM   #1
Default What tool can i use to tighten my hex nut
Hello everyone,
I recently purchased a set of takata green traxxas volk te37 wheels for my AE TC4 and when I go to tighten the nut my wrench doesn't fit in the center of the wheels so it wont tighten all the way is there any special tool I could use to make them fit?
NewXGen is offline   Reply With Quote
Old 09-07-2014, 05:32 PM   #2
gooba's Avatar
I have the same problem with my tc4 and HPI wheels. A small pair of needle nose pliers is about the only thing I've found that works
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 09-07-2014, 05:42 PM   #3
I went to ace hardware and put washers and did it that way for now. I am going to look into finding smaller hex nuts if possible. the ones on there now are wider than my friends tc3 nuts.. but the thread doesn't fit my car so I couldn't use his
Old 09-07-2014, 05:58 PM   #4
Scott B's Avatar
Trader Rating: 43 (100%+)
You can grind / sand down the outside of your nut driver so it fits inside the rim, our find another that has a thin wall so it will fit.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 09-07-2014, 06:30 PM   #5
http://pages.ebay.com/link/?nav=item.view&id=331229913918&alt=web
O'Donnell 11/32" nut driver. It has a thin wall, it's what I use with my TC4 and haven't had an issue.
avink007 is offline   Reply With Quote
Old 09-07-2014, 07:14 PM   #6
nice! ill try that one 4 sure.
Old 09-07-2014, 07:53 PM   #7
BadPanda818's Avatar
Trader Rating: 17 (100%+)
the hudy drivers also have a thin sidewall. I have used it on my TC3 without problems, just the cost
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 09-07-2014, 08:06 PM   #8
I just shaved the center of the te37 wheels with a razor and flipped the nut around and it grabbed and tightened good now without the washers! I will be ordering that tool but for now this will work fine. thanks all for the links and advice
Old 09-08-2014, 08:31 AM   #9
avs
avs's Avatar
wiha's nutdrivers are thin walled and plenty good quality for the price. last I looked they were at fry's. wiha's website catalog isn't easy to navigate, look under
screwdrivers
nutdrivers
precision
Tony Shimko
avs is offline   Reply With Quote
