Problem with Trackstar ESC >
Old 09-06-2014, 03:20 AM
Default Problem with Trackstar ESC
Hi All, Im having an issue with the trackstar 1 cell 120a running in a Mardave. Im using a KO Esprit 2 controller and KO Receiver. Since i tried the car on Thursday Night, (First time it has been used for 6 weeks) I was having issues with the car moving forward slowly when returning to neutral. I tried adjust the throttle trim to no avail. It was a random occurrence when it was happening. When I was racing it last night I had to re calibrate the ESC every time I turned it on. Also, when returning to neutral the back axel was locking causing my car to spin. This was a random occurrence to. Is it an ESC or Transmitter issue?
Cheers
brownerboy97 is offline
Old 09-06-2014, 03:24 AM
maybe even receiver?
rcnutbag00 is offline
Old 09-06-2014, 08:38 AM
Could Be. It has been in several heavy shunts through out its use, I have tried a different pair of crystals and it was the same.
Old 09-06-2014, 06:14 PM
Have you tried to re-calibrate the ESC?
Measuredpath is offline
Old 09-09-2014, 04:59 AM
I have to re calibrate the ESC everytime i turn the ESC on. Otherwise it just sits there beeping at me
Old 09-09-2014, 07:43 AM
Geezatec's Avatar
ESC rated @ 2-6cell, not for 1 cell.
Geezatec is offline
Old 09-09-2014, 10:21 AM
b20btec's Avatar
Even so those trackstar esc have that problem, it'll randomly lock up. They're cheap for a reason .
b20btec is offline
Old 09-09-2014, 10:42 AM
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I just installed a Trackstar GenII 1S 120A in my WGT to try it. So far, no problems. I did pick up the program box and the first thing it did when connected to the PC was update the ESC to 2.02. For blinky, you need to switch to profile 1, rename it to what ever you want so you remember it, set timing to 0*, set turbo to 0* and the white LED comes on to indicate no timing. Then change gearing and the timing on the motor to match the track for blinky. If you just calibrated out of the box and have the timing cranked up, the default "Modify" profile HAS TIMING. Turn your motor timing down to 10* or less until you can get to a PC with the program box. You're probably getting cogging from too much timing.
liljohn1064 is offline
Old 09-10-2014, 05:38 AM
I have the ESC set up as Blinky. The motor is A Speed Passion v2 13.5t. It is set up as sensored and The timing is at 10 degrees if i remember correctly
Old 09-10-2014, 07:38 AM
Geezatec's Avatar
First thing first, Charge battery to full, All trims to 12o'clock, Calibrate TX to RX, Set ESC to 1cell by Memory Card or Blinky. Go from there. May start Cogging, Drop pinion as needed.
Geezatec is offline
